Sport Shift Mode Question
When I drop the shifter down to sport shift mode (2013 V6 Premium Automatic), a screen pops up that says "Sport Shift Mode" and takes up the entire center display screen and the current gear is not displayed. So I have to look at the mph and the tach and guess. Hitting the "OK" button does not eliminate the sport shift mode notification screen. It only goes away after you change gears the first time.
On the 2014 V8 Automatic, no Sport Shift Mode notification comes up at all, it just properly adds your current gear to the display.
So how can I delete that gear concealing notification screen? I have searched the menu trying to figure out how. THANKS
On my 2013 I just hit the "OK" button and the notification screen disappears.
But the current gear is only displayed if you hit the "+/-" button. It doesn't display gears otherwise and the S just has a different shift pattern with a lock out of the overdrive (6th). I.e. it runs like an automatic but with a more aggressive shift.
The 2014 may be different and hitting the "OK" will clear the notification as well as display the gears as the transmission shifts. I haven't been in one to check it out.
Not sure what steering controls you have but on my 2014 base model you have an info/reset button on the left side of the wheel. If you hit the info side of the button first then hit the reset side the display will go back to what is was prior to the Sport Mode message.
It is a little confusing, and it's not obvious that there is a distinct different between the sport mode and the manual shifting mode. Many people just assume (as I did for the first 2 months driving mine) that there are only 2 modes, Normal and manual.
The gear is not shown in D and S modes only in the manual mode
Sport is an aggressive shifting mode and as far as I know there is no way to show the gear being used.
Once you press one of the +/- buttons while in Sport more, you then switch to manual shifting mode, and then the gear is shown.
The bug I think is that you cannot go from Manual shifting mode to Sport mode without going to Normal (D) first.
"Many people just assume (as I did for the first 2 months driving mine) that there are only 2 modes, Normal and manual."
That solved it. I thought the "S" was for Select Shift - turns out it's a very nice Sport Mode - tach lives above 2krpm, engine braking seems to be enhanced beyond the increased rpms, shifts are faster - nice. I assumed there were only two modes for the first 3 weeks. Drove it in Sport, nice. Better engine breaking, faster shifts. Later shifts.
StangDawg - changing to a different screen like that doesn't affect my car. It doesn't matter which center screen I have displayed if I put it in "S" I get the pop up screen that says "Sport Mode"
I wonder why our cars are different? Seems like the programming would be the same. (not that I am questioning what your car does, just odd our cars are different).
