351 Mustang
converting 302 to 351
Old 01-04-2007, 03:07 AM
rallycar01
rallycar01's Avatar
Default converting 302 to 351
Im 21 years old an have been wanting to convert my 1989 hatchback 5-speed 302 into a 351. I recently found a "complete" 1978 351 Windsor for $150, and basically wanting to know if #1.) Good Deal #2.) Would the 1978 351 be able to replace the 302 #3.) Would it need to be changed to carb or would the fuel injection be ok to use #4.) How much trouble am i getting myself into????... please help...Thanks...
rallycar01 is offline
Old 01-04-2007, 03:25 AM
89Ford
89Ford's Avatar
Default RE: converting 302 to 351
it could be a good deal it all depends...and for the rest of your questions i give you one answer, read this http://www.freewebs.com/vristang/fox351wswapfaq.htm (sorry Jason, I know you would have posted it but I wanted to beat you to it)
89Ford is offline
Old 01-04-2007, 03:29 AM
rallycar01
rallycar01's Avatar
thanks
Old 01-07-2007, 04:43 PM
vristang
vristang's Avatar
ORIGINAL: 89Ford
Actually...
How flattering...
*blush*
The year of the block won't cause any issues, other than affecting roller lifter selection.
The 5.0HO, A9* computers will handle a mild to moderate 351w with relative ease. A tune would be best, but in no way is it required.
Stock 302 or 351w heads will limit power, but do work fairly well if need be.
$150 is pretty decent.
Is it a complete long block?
What kind of shape is it in...
As you can tell, I think the swap is well worth the effort.
Feel free to post questions!
vristang is offline
Old 01-07-2007, 05:06 PM
rallycar01
rallycar01's Avatar
The block is almost complete. Missing upper intake and cam....but who cares...i prolly would just sell the intake anyway...planned on stroking it so would need new cam and heads and other misc. stuff as well. When the block had everything on it I went and looked at it and it turned over by had real smooth. but im going to get everything checked out on it by the michinest make sure no cracks and stuff. And i had planned on getting alum. heads too. When i get my mustang mags i always just want to see the 351 articles and look at the specs and if they run low 11's thats exactly want im going to do....just seems so hard to do everything right and i duno if im going to be able to get everything right where i dont screw somethin up and break stuff. i duno...how fast do you guys think it will do with doing all this to it?
Old 01-09-2007, 08:29 PM
ddeaton66
ddeaton66's Avatar
If one was to swap in a 95 roller block, complete upper to pan (into an 86 Fox) what would be the best short term (=cheap) route to go with the MAF (have to convert from SD at the same time). Use a stock 5.0L MAF or the stock 5.8L MAF? I have read that an A9* EEC will work good enough for a while on a stock 5.8L engine.
TIA
ddeaton66 is offline
Old 01-10-2007, 02:39 AM
89Ford
89Ford's Avatar
an A9L or A9P will work fine with a 5.8L engine. the 5.8 MAF computers are junk from what Ive heard
89Ford is offline
89Ford
89Ford's Avatar
and i dont think you can use the oil pan, you need a swap pan
89Ford is offline
Old 01-10-2007, 08:11 PM
ddeaton66
ddeaton66's Avatar
Thanks....I'm trying to piece this swap together, it's harder to do w/o a 5.0 for parts.
Old 01-20-2007, 04:53 AM
rallycar01
rallycar01's Avatar
As i going to the 9 qt pan ......89for....you sent the sight above that said the MAF would work fine......But from other post i seen said diff....so seriously which is best...and what size??? thanks...by the way picked it up for $100 since didnt have the intake...but planned on going GT 40 if possable....is it???
Quick Reply: converting 302 to 351
