I bought this stang out of state from an used car dealership. When I first test drove the car it was great. It all started on the drive home. The car just shuts down, I ended up having to tow the car 900 miles to make it back to AZ from TX. It turned out the alternator was bad. I replaced the alternator and battery (since it was over 5yrs old). All was well for a couple of days of normal driving. Then one day it just died while going 35 mph. It cranked backup immediately and I was able to drive home without incident. A couple of days go by and no problems. Then yesterday after letting my brother drive it, and he got on it a little, it starting shutting down again. This time about every 3-7 minutes of driving. The car has no problems starting back up; that's what's wierd. It does this while driving or just sitting there idle. Here is the cars config:
95 GT
351W sportsman block
AFR 185 heads with spring upgrade
1.6 roller rockers
JE forged Pistons
Cat 4340 forged rods
forged push rods
Cat 4340 forged crank
383 stroker kit
Cam with 112 degree lobe separation 228/233 @ .050 duration 560/575 lift
9.7:1 compression
Canton 7quart oil pan
Melling High volume oil pump
Oil cooler,
fluidyne radiator
electric fan
SVO 1 5/8 ceramic shorty headers
Complete Aeromotive fuel system with sumped tank A1000 pump & Adj regulator, SB lines, Aeromotive fuel lines.
TrickFlow upper & lower intakes
50 lb Holley injectors
Anderson Ford Power Pipe
Vortech V2 S Trim 8 lbs boost (2.95") pulley
Pro-m 75mm Mass air meter
Mac 70mm TB
EGR spacer
MSD 6 AL ignition with MSD boost retard, MSD coil
Stock Ford distributor with Accel 8.8 wires
D&D performance T56
Pro 5.0 shifter with tri-ax handle
FRPP aluminum DS
Billet Steel flywheel
McCloud Dual Disc clutch
373 gears
Aluminum upper & lwer control arms
SubFrame connectors (welded in)
Steeda CC plates
BBK lowering springs
KYB adjustable shocks & struts
Cobra brakes on all fours
Bassani X pipe w/hi flo cats
Borla cat back
Autometer, volt, fuel pressure gauge, VAC/Boost gauge & AFR gauge.
Autometer pillar dual gauge pod
Saleen Dash Dual gauge Pod
Saleen 200 MPH gauges
Saleen Pedals
Saleen full body kit
Saleen S351 wing
Saleen Heat extractor hood
FR500 Steering wheel
Cobra 6sp leather shifter knob
18X9 & 18X10 American racing rebel wheels
Nitto NT555 265 35 18 (FR) & 285 35 18 (RR)
Things I've noticed before and after this issue happens
fuel pressure at 40 psi at idle and increases porportionally with pedal input
Vaccum at 10 in Hg doing 35 mph decreases with pedal input
water temp at 165 degrees when initial shutdown happens
smell of fuel when sitting in garage overnight appears to be real strong from passenger side engine compartment
Voltage at 14.5 when engine running (new alternator only 3 days old)
Battery Voltage 12 volts static (new battery only 5 days old)
Oil level good and clean
coolant level good
No check eng light on shut down, but I do get check eng light on occassion after driving it a few miles but not shut down (this was prior to the shut down issue starting) and the car appears to be OK
20K on motor
75K on chassis
Let me know if you need anymore info, this all I can think of at the moment. When I test drove the car before I bought it, it was fine and damn awesome. Right now it is my worse nightmare...having a unreliable Stang in my garage. I'm new to the 5.X motors, I came off the 4.6 bandwagon.
I suspect something in the ignition system. Fuel system appears to be OK when running. It seems to shutdown consistenly at approximately 3-7 mins running cold or hot. Help!!!!!!
Thanks. Dave
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
__________________
1995 Saleen S351 Replica. 351 Sportsman block, Forged Bottom end, Trick Flow upper/lwer intake, Aeromotive A1000 fuel system + adj fuel press reg. Vortech V2 Strim 8lbs boost, Andersen power pipe, Maximum Motor sports UCA & LCA, 3:73s w/ Girdle, Canton 7Qt oil pan, 50 lb injectors, Fluidyne radiator, genuine Saleen body kit, S351 wing & heat extractro hood, Nitto NT555, Aluminum fuel door, Cobra brakes F&R, T56 transmission, aluminum DS, BBK lowering springs, Steeda CC plates, Optima Battery.
Thanks I'll take a look at that today, I also read a forum post on MSD's site and the MSD tech suggested replacing the distributor. Thanks. It's a start in the right direction.
Dave
__________________
I also plan on replacing the spark plugs. On this type of setup what do you all think the gapping should be? and what spark plug do you recommend? Iridium or platinum? Brand? Thanks.
__________________
NGK or autolite... and dont run iridium OR platnum
Why not iridium or platiunm? Too hot? or just not worth the extra cash?
the ignition system in your car is not designed to run with them, and for the money, will give you lack luster results. Stick to a normal resistor or copper core plug
Well, I went ahead and ordered a new MSD distributor, coil and wires direct from MSD. I'll be picking up plugs today from Autozone and an ignition switch. I've had this car for 2 weeks now and really want to start driving the thing. MSD is out of El Paso, TX so I should have the stuff by Friday. I'll post the results after I swap out the parts. Wish me luck. Thanks for all the input.
__________________
