351 Mustang
351 windsor fuel enjectors
Old 06-16-2010, 10:08 PM
morgan62
morgan62's Avatar
Default 351 windsor fuel enjectors
i have a 302 i would like to know if 351 fuel enjectors would work on my 302 or if i will have to change any thing to make them work i have e303 ford racing cam flat top pistons ; heads ported and polished other than that it is stock
morgan62 is offline
Old 06-16-2010, 10:39 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
depends if they have the same connection as your injectors and if they are the correct poundage....
i used Explorer injectors on mine they are more efficient 4 hole same plug and 19#'s
rmodel65 is offline
Old 06-16-2010, 10:46 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
Why would you want to change them? Your mods do not need bigger injectors. Do you what duty cycle yours are at now?
JD1969 is offline
Old 06-17-2010, 11:31 AM
Venomantidote95
Venomantidote95's Avatar
Depending on color if there oe ford injectors will determine the size!
a 19 will be a 19 i doubt a 3 or 4 hole pattern will make any difference ! you still hvae a 19lbs inj!
you definatly dont need a bigger injector unless you were gonna spray dry or charge it!
an adj regulator will go a long way with your 19`s and your setup!
Venomantidote95 is offline
Old 06-18-2010, 01:54 AM
gtnby2
gtnby2's Avatar
YES!!! an adj reg and a 255lph pump will make a BIG differeance....did in my car when i had a 306 in it.
gtnby2 is offline
Old 07-12-2010, 03:58 PM
mattkoly
mattkoly's Avatar
If they are a different size injector you will have to get your MAF calibrated
mattkoly is offline
bradleyb
11-27-2015 07:50 PM
Sixx
10-05-2015 07:36 PM
svfetter
10-05-2015 11:39 AM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
mrappe
09-26-2015 10:16 AM
Quick Reply: 351 windsor fuel enjectors
