351 Mustang
is .60 over ok?
Old 07-29-2010, 09:21 AM
5.0kid
5.0kid's Avatar
Default is .60 over ok?
im looking into buying a motor from a fellow buddys friend and the block is .60 over its a 1970 windsor block the combo has gone 8.50s on a 250 shot the only thing worrying me is if .60 is pushing it when it comes to cylinder wall thickness.
5.0kid is offline
Old 07-29-2010, 11:58 AM
.boB
.boB's Avatar
For racing, yes, it's pushing it a bit. The big thing is to make sure your cooling system is much bigger than you think it needs to be. Excess heat can kill it.
.boB is offline
Old 07-29-2010, 07:24 PM
5.0kid
5.0kid's Avatar
its gonna be a quarter mile mule will not likely see full operating temp at any time so i think im ok with my fluidyne radiator and electric fans. so maybe buy the motor and look to invest into a boss 351 and punch it to .60 over to be safe?
5.0kid is offline
Old 07-30-2010, 06:33 PM
.boB
.boB's Avatar
If you're going to invest in a Boss block, why not punch it out a lot more? Max is 4.125" Bigger is better.
.boB is offline
Old 07-31-2010, 01:07 AM
5.0kid
5.0kid's Avatar
so i can have some meat if i score a cylinder for it to be bored a few times
5.0kid is offline
Old 08-12-2010, 06:58 AM
uedlose
uedlose's Avatar
it maybe just fine and then maybe not. Take it to a machine shop and have it sonic checked for thickness and see what they say I have heard of them gone over .060 with the older blocks.
uedlose is offline
Old 08-18-2010, 07:31 AM
wildcobrar
wildcobrar's Avatar
If it is a stock block and .060 over bore and has alot of running on it you may not wish to buy it. Wear = taper and it will need to be bored more to straighten it out.
Personally, i do not buy anything in stock blocks that are .060 over. The only way I will take one is if it is given to me. It is a crap shoot for rebuilding it.
If it is a running engine and no blow-by and good compression and leak down test is good. Then maybe it would be a decent buy.
Joe
wildcobrar is offline
Old 08-18-2010, 02:10 PM
.boB
.boB's Avatar
Consider a Dart block. Pretty much the same money, and certainly a high quality/well known product. 4.125 is minimum, with another .060" if you need it later. Couple that with a 4.000 stroke crank, and it will easily run to 7,500 rpm's.
.boB is offline
Old 08-20-2010, 10:06 AM
GTnotchback
GTnotchback's Avatar
uhh my engine is .060 over on my block in my sig. Why is that a problem? am i missing somthing. i had it done @ .060 right when is was brand new.
GTnotchback is offline
yourmom6990
10-01-2014 07:14 AM
Dougw133
07-07-2013 09:48 PM
luizGT91
351 Mustang
02-05-2008 11:47 AM
muggsy
02-25-2007 01:26 PM
drewguere
09-11-2006 02:05 PM
Quick Reply: is .60 over ok?
