351 build opinions
351 build opinions
whats up guys, I'm about to buy a 88 coop that has a carbed 302. I want to do the 351 efi swap. I've been reading up on this but cant find a diy carb to efi 351. I'm also going to end up supercharging it. So What parts should i get instead of stock ones? exp fuel pump, pistons, heads, intakes, any info would be greatly appreciated.
Hey guy
Does that 88 coupe still have the wiring harness that came with the motor? '86 was the first year for EFI in mustangs, so yours has been already converted from efi to carb once. You'll need a wiring harness and computer to control the motor. Other than that, everything is basically the same besides little misc parts here and there. Pistons and heads are interchangeable between carb/efi, but the intakes will be different. I'm pretty sure the distributor is a little different too but I could be mistaken.
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
