351 Mustang
351W to 438W Aftermarket Block
Old 02-26-2013, 10:45 PM
BlessedHellride
BlessedHellride's Avatar
Default 351W to 438W Aftermarket Block
I bought a big bore block a couple years ago, Pro Comp block that has the 4bolt mains on all 5 journals. I have a couple of questions.
1. What oil pan will fit these aftermarket blocks? I was told that they are the same as a Dart IE as far as fitment.
2. What model # MSD distributor is needed to run with a Victor Jr Intake?
3. Any good leads on a good set of headers to fit AFR 225's wide bolt pattern would be appreciated also. Thanks
BlessedHellride is offline
Old 02-27-2013, 12:33 AM
Duncan_GT
Duncan_GT's Avatar
Call Accufab and have customs made. George will set you up with exactly what you need
Duncan_GT is offline
Old 02-27-2013, 07:12 PM
uedlose
uedlose's Avatar
Moroso makes real nice oil pans that will clear the 4 bolt main blocks. they make cheaper one and then they the $$ ones. but even the cheaper ones are real nice.
uedlose is offline
GimpyHSHS
19
12-19-2023 01:12 PM
guitarman376
09-30-2015 05:54 PM
mustangheaven
09-29-2015 11:00 AM
wraith777
09-28-2015 10:49 AM
09-24-2015 09:18 PM
Quick Reply: 351W to 438W Aftermarket Block
