351 Mustang
Cobra Automatic
Old 08-11-2014, 07:05 PM
PHSeaBee
PHSeaBee's Avatar
Default Cobra Automatic
Years ago bought a 94 Cobra. A short time later I bought a 93-95 Lightning block and installed a Crane Compucam 2030 with Twisted Wedge heads. All the cobra parts( 24lb injectors, 1.7 rocket, intake ect) was installed the car was a lot of fun. I was called to active service and when I came home I needed to change the car over to an automatic. Soooo... We pulled the 5spd and ecu ( since the Trans is computer controlled) out and swapped with a guy who wanted a T-5. I'm ready to install the AODE into car but was told I F'd up. The ECU won't operate with the engine and mods because of the injectors?? I'm looking for the correct way to make this install work. I've been told a called MAF...a chip...it won't work...change to OBDII... And it goes on. Please tell me what YOU have done and works. Thanks
PHSeaBee
At
Yahoo
If ya need to email me...
PHSeaBee is offline
Old 08-12-2014, 11:53 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
just call pro-m up and get a maf for a 94 that is cal'd for 24's, let them know if you have a CAI as well for cal
mjr46 is offline
Old 08-13-2014, 07:21 AM
64bit
64bit's Avatar
PHSeaBee
At
Yahoo
You need to buy a 94-95 GT ECU (W4HO), The automatic transmission sub harness, As well as a torque converter/OD controller. All parts will plug directly into your harness and are required for proper operation.
I would love to help you out, so I'll be sending you an e-mail. Here's mine just incase.
64bittuning@gmail.com
We can address all of your issues in one place, at one time.
64bit is offline
Old 08-13-2014, 08:49 PM
uedlose
uedlose's Avatar
Thumbs up
Or you could get the ECU back and just convert the trans over to a full manual valvebody and have the best of both worlds the auto and shift it like a stick. and just get rid of the ecm control of the trans. Also not changing all the parts out would help keep it close to original also. it would also be a lot less work .To the OP Thanks for your Service also.
uedlose is offline
Old 08-15-2014, 06:23 PM
PHSeaBee
PHSeaBee's Avatar
just to be clear.... if I buy this Pro-m MAF cal'd for the injector size I won't have any ECU issues? No need to chip it? thanks I was told this is an ECU "trick" and wont really work. That's why I was asking for what has actually been done not he "I think this should work" kinda things I hear on other sites.. thanks again
PHSeaBee is offline
Old 08-17-2014, 08:15 AM
64bit
64bit's Avatar
You can do it cheaper and more reliably with a chip. Calibrated MAF's are not the right way to go. you can cause idle issues, stalling, surging, bucking etc. Cal'd maf's work great in foxbody cars, not so much in SN95's. ESPECIALLY in an auto.
64bit is offline
Old 08-27-2014, 04:07 AM
84CopperGT
84CopperGT's Avatar
Why not keep the old ECU and use a stand alone transmission controller? That's what I had on my old Corolla and it worked great.
84CopperGT is offline
Old 08-28-2014, 05:22 AM
bluebeastsrt
bluebeastsrt's Avatar
The calibrated maf will work fine!!!!! That's what everyone does when they go to bigger injectors. Don't over think it. If you already have a pcm for the automatic your in good shape. Did you get the wiring harness that goes with the pcm when you traded? If not the automatic harness can be had for cheap on eBay.
bluebeastsrt is offline
Old 08-28-2014, 07:29 PM
PHSeaBee
PHSeaBee's Avatar
Yes, I have the AODE, w4h0 ECU, converter/flex plate, harness w/ module and radiator w/ lines...what ever he had to pull out I had to put in and vice versa. ya, I know better deal for him but if I can make this work; I have a car that isnt just sitting again!
PHSeaBee is offline
b8checker
10-08-2015 12:55 PM
88 orangepeel notch
10-05-2015 09:03 AM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
Quick Reply: Cobra Automatic
