351 Mustang
need suggestions
Old 12-14-2014, 02:30 PM
ocalastang
ocalastang's Avatar
Default need suggestions
I am building a junkyard dog. using spare parts I have laying around. here is what I got so far
1994 gt convertible with automatic
1984 351w bare block punched .030 over
393 rotating assembly
190cc aluminum heads with 1.7 roller rockers
dual plane carb intake
200cc roush cast iron heads with 1.7 rockers
trick flow upper and lower intake for 302
complete harness and computer out of a 89 lx coupe that had a manual trans
I am thinking about buying the link bar lifters, custom cam, and build the 351w to a 393. thought about buying the lower intake to match the trick flow upper that I already have and install the harness from the 89 into the 94 and maybe run a c6 or maybe even a glide. I done want to spend a lot of money cause, like I said. this is a junkyard build that im hoping to run strong. should I even waste the time with the efi and just go carb? I would like to hear other people suggestions and ideas. 2 heads are better then one.
thanks
ocalastang is offline
Old 12-14-2014, 04:15 PM
bluebeastsrt
bluebeastsrt's Avatar
What do you plan to use the car for? Carb wont pass inspection here in jersey. Don't know about flordia.
bluebeastsrt is offline
Old 12-14-2014, 09:21 PM
barnett468
barnett468's Avatar
well exactly what kind of intake, name of mfg and model?
what are the aluminumn heads?
are they ported?
link bar lifters are not exactly "budget".
do you wany bottom end power or bad bottom but 6500 rpms?
in general, either efi or carb are fine performance wise tell you bwhsat of the parts you have you should run
if you want a custom cam then they can tell you what of the parts you have you should run.
if you need a custom cam guy, i would call scott main at cam resesarch . . his engines have won pro nhra world championships, set nhra redords etc.. and he is a ford guy.
http://www.camresearchcorp.com/street-cred/
also try bullett cams.
http://www.bulletcams.com/
barnett468 is offline
Old 12-15-2014, 05:40 AM
ocalastang
ocalastang's Avatar
The aluminum hEads are the cheap procomp set. Bought them really cheap. This car is going to be a street car might go to the track from time to time. Mainly driVing to and from the shop and have a little fun doing it. Lol
Old 12-16-2014, 06:18 AM
64bit
64bit's Avatar
I don't even know where to start on this one, putting that 89 harness and is probably the biggest mistake youll make.
64bit is offline
Old 12-17-2014, 09:59 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
It doesn't matter, it's what is needed to "properly" do a roller conversion in a non-roller block......end of point!
mjr46 is offline
Old 12-17-2014, 10:00 AM
mjr46
mjr46's Avatar
florida last I knew when I was in Daytona doesn't have vehicle inspections.
mjr46 is offline
Old 12-17-2014, 11:14 AM
bluebeastsrt
Cool carb away then. Living in Jersey is a little like living in **** Germany.
Old 12-17-2014, 06:33 PM
bluebeastsrt
LOL I would have loved to read the unedited version. I think you guys will be good buddies one of these days.
Old 12-17-2014, 09:27 PM
vegasmax
vegasmax's Avatar
Use a harness off a 5.0MAF engine and a Mustang ECM buy the procomp headers off Ebay.
vegasmax is offline
Quick Reply: need suggestions
