Cams and Heads
RE: Cams and Heads
Yeah I'm debating between the X-Charger and the ProCharger because they seem to put out the most torque. the X-charger puts out insane amounts of torque!! But if I decide to do cams and heads then it'll be a little longer... So many things to do... lol
RE: Cams and Heads
If you're going to do heads and cams with the intention of going FI in the future you should also save up and put in forged internals to handle more boost, and if you are going to do that you might as well do the stroker kit! Imagine a FI Stroker motor with ported heads and agressive cams! 400rwhp V6 baby!
RE: Cams and Heads
just a note. it so far hasnt been proven neccasary that you need to build the motor to run any of the f/i systems. You will need this however when you up the boost plus it could be a layer of safety. I plan on going built motor myself this summer when my truck is out and ready to go for the summer time.
RE: Cams and Heads
stroker kit=more displacement=more room for more air and gas=more power
on the topic-i think heads and cams would be a good investment once F/I or right before. Would definetly enhance the power with every mod you put on the motor most likely....even though don't know how much further you could go after f/i heads and cams!
ORIGINAL: AmericanMade
Newb Question!! What's the stroker kit?? lol!
RE: Cams and Heads
ORIGINAL: beaustang
yeah, but if ur gonna go X-Charger whats the point of bothering with forged internals as you won't be able to up the boost as theirs no aftercooler. But i could understand just putting in lower compression pistons(forged that is) to increase the boost, might as well upgrade the weakest link while your in their. With the combination of X-Charger, Heads/Cams, 8.8 compression pistons i wouldn't expect it to make anything more than 340-350wph at BEST at the Hi-pro psi of 8-9psi? not sure which psi the hi pro uses.
RE: Cams and Heads
Okay guys I know this is a odd concept... Try and step away from the pre fabbed turbo kits here. If your shooting for big numbers your obviously going to have to do some custom work. Instead of going procharger, xcharger, blah. Build your own turbo setup. Choose a good garrett gt ball bearing turbo. Choose a good intercooler for the correct size, piping is simple to do or you can have someone do it for you for a couple hundred. From their you get a larger fuel pump about 100$ and larger injectors. You will need a b.o.v. and a wastegate if your turbo has not included one. Expect to spend 3-5k on the turbo setup alone depending on parts used and how much outside labor is used.
Now if you want to get big number you will need forged internals. I would start with the stroker kit from here
http://www.moranav6racing.com/catego...?CategoryID=32 . Then move onto doing your camshaft, headstuds, heads. You are going to spend about 10k on this motor. . . so far So i Hope the numbers in your head are closer to 500rwhp. Which is possible it depends on the work you do to the motor. So if you really plan on spending that much money on a stroker kit to go f/i. Please think about swapping motors. Its definetly worth it to get something bigger and more reliable. Remember you jump up in power over 400hp you will need to upgrade to a 8.8/9" rear end, different driveshaft, tranny, and upgrade your suspension.
my information may not be spot on, correct it as you will
RE: Cams and Heads
ORIGINAL: lrgnation
RE: Cams and Heads
ORIGINAL: beaustang
http://american-speed.com/collective/forums
oh and irgnation...the ph turbo can support something like 650hp...their car is running mid 11's on it and a stock long block. the procharger can handle well into 500 horses with the d1sc unit. If it is big power you want, the ph turbo, the vortech, and the procharger are all good ways to go. the x-charger is more of a street unit that can go to the drags also. it isn't capable of such huge numbers because there is no intercooler option as of yet, but if you are aimin for low 300's and monstrous torque...xcharger and heads will do no wrong, but if you want high 300's+ you are gonna need a centri blower or turbo. any way you go, with the extent you are suggesting you are going to go, you are gonna have a monster!
RE: Cams and Heads
Yep, 8cd03gro is right. Flapjack and Gash have done it. Gash is a NA car that has heads, should have a write up today from him and dyno over the next week. Flapjack did the head/cam install himself, his a direct link to his write up:
http://american-speed.com/collective...ead.php?t=3843
Very good write up with pics, list of tools needed, etc.
