2007 Mustang V6 Mods Suggestions
Old 04-13-2012, 10:00 PM
pardopachiv
pardopachiv's Avatar
Default 2007 Mustang V6 Mods Suggestions
Hi guys,
I'm thinking about doing few mods to my 07 V6 pony. I have a list of modificaitons I would like to do; your suggestions and insights are much appreciated.
1. Ford Racing Air Intake Kit with the Pro Cal tool (Does any one have experience using FRPP's Pro Cal tuner? or I can switch it to SCT3. Compare to other major brand of CAI like K&N, JLT, Airaid, C&L and AEM, how is the reliability anf performance of FRPP CAI?) K&N and JLT are the most likely alternatives I have in mind.
2.FRPP 7.5" 3.73 Ring&Pinion and installation kit, FRPP Traction Lok, any other parts should I install when changing the gear ratio?
3.FRPP Single Rear Axle Back "Touring"
4. BBK Throttle Body 70mm; I read that TB Spacer is a waste of money...so I probably will pass on it.
5. Screaming Demon Coil with live wires and upgraded sparks (any quality live wires and sparks for suggestion? Is this mod worth doing or not?)
6. Underdrive Pulley, as far as I know, ASP would be my only choice so far.
7. JBA Cat4ward Shorty Headers (debating, some say it just give better sound not performance-wise)
Lots of questions, again, your help is much appreciated!
pardopachiv is offline
Old 04-14-2012, 08:07 AM
157dB
Cut & Paste Expert
157dB's Avatar
1. C&L FTW
2. 8.8" GT rear end with 3.73s and traction loc already installed
3. yes
4. BBk is a waste of $$ unless you have the cams to support it
5. again, screamin is no better than the OEM coil Taylor wires FTW
6. yes
7. yes
157dB is offline
Old 04-14-2012, 08:13 AM
Nuke
Nuke's Avatar
This is a duplicate thread from the V6 S197 General Discussion forum.
Nuke is offline
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
MustangV6P
09-28-2015 11:00 PM
Suree_Mustang_2009
09-25-2015 12:58 PM
Quick Reply: 2007 Mustang V6 Mods Suggestions
