New o2 sensor = CEL codes
Old 05-27-2012, 02:26 AM
scooter09
scooter09's Avatar
So I did some more browsing under the hood and my "engine #1" fuse is blown .... Cause for a/c not working?
scooter09 is offline
Old 05-27-2012, 06:41 AM
Bitter
Bitter's Avatar
Check your owners manual but I'm pretty sure fuse #1 in the distribution block under the hood is not used.
Not too long ago, I had one of my vehicles in the shop for work (not my Mustang). Even though it didn't involve the A/C, they had to discharge the coolant. I'm assuming it was because they had to move an A/C component out of the way. Usually they can capture it and refill it. Any chance they had to discharge yours and forgot to replace it?
Bitter is offline
Old 05-27-2012, 09:40 AM
scooter09
scooter09's Avatar
The manual said the fuse name is engine #1 I forgot the actual fuse number ... As for discharging the a/c the said they only touched my transmission and that one o2 sensor they did nothing with the a/c
Old 05-27-2012, 10:17 PM
scooter09
scooter09's Avatar
In another attempt to see if it's my tune causing the sensor error I ran my tank dry and filled her up with 93 octane fuel and loaded my 93R tune ... Not taking advantage of the situation or anything lol drive safe everyone! Will update if the CEL comes on again ... If not then I've found one awesome cure
Old 05-29-2012, 08:58 AM
scooter09
scooter09's Avatar
Update so far
Found out my "engine #1" fuse controls my egr evap control and o2 sensors so I bet the o2 sensor the mechanic put in had a short which caused the fuse to blow which is causing my CEL so after work today I will be visiting him and the owner to have a nice discussion about my findings and hopefully get it replaced with a proper and functional o2 sensor and fuse
Not sure if that is also causing my a/c to stop blowing cold
Old 05-29-2012, 01:48 PM
kevinmalec
kevinmalec's Avatar
Sorry to hear you are having to go through this. I recently had to replace my whole clutch assembly and experienced no issues. I had to get used to the clutch grabbing really low and also the clutch pedal is super light to push down.
Does your clutch pedal feel alot lighter than your original?
One minor thing they forgot to do was plug the brake connectors back together and my brakes weren't working. I had a lady speed up beside and me and was nice enough to yell at me. LOL I took it back to the shop and 30 seconds later all is good!
Hope you are able to get everything resolved, at their expense!
kevinmalec is offline
Old 05-29-2012, 06:31 PM
scooter09
scooter09's Avatar
Update
They removed all o2 sensors and the fuse is still popping so I get to come back tomorrow for another crack at it.
@kevin
Yes at first the clutch was VERY light but after around 100 miles it's been tightening up
Old 05-30-2012, 08:39 AM
kevinmalec
kevinmalec's Avatar
Originally Posted by scooter09
Update
@kevin
Good to hear they are working with you and trying to resolve the issue.
I was told the pressure plate was revised, to lighten up the clutch pedal. I am starting to feel the clutch pedal tightening up a little, which is a good thing. =-)
With the new clutch, do you feel the car pulls as hard?
Keep us posted!
Old 05-30-2012, 10:34 AM
scooter09
scooter09's Avatar
@kevin
I didnt put an oem clutch in so i cant really compare I put a precision performance clutch assembly in clutch pressure plate flywheel slave and TO bearing ... It is VERY grabby...it doesn't slip under any condition as soon as I hit the friction point it grabs hold and im in my seat
And yes they are working with me but getting it fixed is a better solution lol
Old 05-30-2012, 02:43 PM
kevinmalec
kevinmalec's Avatar
@kevin
I had to replace out everything you listed above as well, but I went with the OEM. The sport clutch quote was a good bit more.
Getting it fixed would be the best solution, I hear ya man! LOL
Quick Reply: New o2 sensor = CEL codes
