changing rear timing belt
Old 06-05-2013, 01:16 PM
pantherpaw
pantherpaw's Avatar
Default changing rear timing belt
I have no idea how to change the rear timing belt on this 06 mustang 4.0 v6.
Motor is out, but having issues on how to change it and re-installing motor, with out messing stuff up.
Any help would be appreciated.
pantherpaw is offline
Old 06-06-2013, 02:06 AM
tx_zstang
tx_zstang's Avatar
First of all, there is no timing belts. Chains are used.
Use the ford service manual to see what is needed to properly but one of these together:
http://iihs.net/fsm/?dir=148
tx_zstang is offline
Old 06-06-2013, 04:33 PM
Lem-06
Lem-06's Avatar
if your having problems with the motor acting up you may want to post what its doing.
going in blindly, especially when you think the engine has a belt and doesnt is gonna cause problems
Lem-06 is offline
Old 06-06-2013, 09:15 PM
2005Redfire6
2005Redfire6's Avatar
News to me, I didn't know there were chains on the back side of the motor -_-
2005Redfire6 is offline
Old 06-07-2013, 12:31 AM
akdoggie
akdoggie's Avatar
Only on one side (rt I believe). The other side is in the front (left side). Each head has a camshaft, so each head has a chain. Look at your valve covers. You'll see the extra part of the valve cover.. That is where the chains run.
akdoggie is offline
Old 06-07-2013, 12:56 AM
Lem-06
Lem-06's Avatar
ha, looked it up and they actually did shove a chain in the back, all i can think is WHY?!?!?!?!?!?
was it that difficult to get the 2nd chain upfront like the v8 has?
Lem-06 is offline
Old 06-07-2013, 08:49 AM
2005Redfire6
What a pain in the ***, luckily it really doesn't become an issue on these motors.
Old 06-09-2013, 08:57 PM
RideThePony2007
RideThePony2007's Avatar
Actually, it can be a pretty common pain in the *** for these motors (4.0L). Its actually partially German engineered so that may explain some of the complications.
If there is one thing the 4.0L SOHC engine is common for, its for the timing chains breaking. Explorer's, Rangers, Mustangs...anything with the 4.0L. And when the rear timing chains break, you basically have to remove the engine to fix it so its a pain. An Explorer came into the shop I work at and I ended up just putting in a reman'd engine becasue of it and warranty and what not. Who knows....maybe my 4.0L mustang will be next *knocks on wood*
RideThePony2007 is offline
Old 06-09-2013, 09:14 PM
steev
steev's Avatar
So what I am reading from this is to buy and build up a 4.6 or maybe 5.4 ready for when the 4.0 breaks...
steev is offline
Old 06-09-2013, 09:33 PM
pascal
S197 Section Modder-ator
pascal's Avatar
We all love that idea but easier said than done when it comes to hook up all the electronics.
Then your rear axle and T5 will give up the ghost past the 300hp mark.
But if going V8, I say build a 5.4.
pascal is offline
Quick Reply: changing rear timing belt
