Rear end "swaying"
Old 07-07-2015, 02:06 PM
Keep it real
Keep it real's Avatar
Default Rear end "swaying"
Just a few weeks ago I started to notice the rear of the car feeling like it was kinda shaking back and forth. At first I thought it was the road but since it feels like it does it more. Only mods I have that could be related are lowering springs and a panhard bar. It does it usually 35-60 and at no specific times. Any ideas.
Keep it real is offline
Old 07-19-2015, 11:36 AM
07RetrostangV6
07RetrostangV6's Avatar
My '07 Coupe is doing the same thing-- My car has 152,000 mi. on it and just started doing it a few months ago when I'm driving on the freeway.
I jacked it up and checked tightness of rear LCA and the rear GT sway bar I put on 5 yrs. ago--everything seemed tight.
My car is stock except for:
Roush rear 1" lowering coils
adj. panhard rod
GT takeoff rear sway bar
catch can
The only thing I didn't check was the small upper control
arm that mounts on top of Diff.
Please post if you find the source of your sway.
thanks,
chris
07RetrostangV6 is offline
Old 08-09-2015, 02:23 AM
Mnuckolls
Mnuckolls's Avatar
Worked on one a few years back broken pan hard bar. Connects from bod to axle. Look up under the rear tires and check your suspension... The one I worked on was so bad, barely pushing above wheel well moved the car six to eight inches back and forth. Real dangerous to drive w busted suspension parts. Could be rotted bushing too. Check thoroughly, and inspect bushings and bolts too
Mnuckolls is offline
Old 09-11-2015, 08:51 PM
2005Stang
2005Stang's Avatar
Also check the simple thing, tire air pressure mine was just feeling the same way and I checked the pressures and both back tires were low on pressure, aired them up and now she feels good!!
2005Stang is offline
Old 09-13-2015, 07:07 AM
JJHoover
JJHoover's Avatar
could be a bad bushing in your LCA
JJHoover is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Rear end "swaying"
