Front Front brake pad hooks - where do you put them?
Old 12-29-2016, 03:30 PM
bighank
bighank's Avatar
Question Front Front brake pad hooks - where do you put them?
Which front pad hook goes WHERE?
Got a new set of front brake pads. 2 of the pads have no hooks on them. 2 of the pads have only 1 hook on the end. One hook in one end and the other hook on the other end. It seems that they could go on either side of the caliper and could be on the leading or trailing edge. Where is the proper place for the hooks? Outside or inside on the caliper and leading or trailing edge?
bighank is offline
Old 12-29-2016, 04:12 PM
jz
jz's Avatar
Have you disassembled the existing brakes already? I always compare the new brakes to the existing brakes before removing anything.
jz is offline
