starting probs
starting probs
what's up guys, having some problems getting my 95 5L to start when it's warm...cranks forever before starting if either the car or the weather is warm. starts like a champ though when cold. thanx for the help.
starting probs
I'd check your idle air control valve (it's mounted on the throttle bodies on 5.0s). They are notorious for sticking when temperatures change. If it gets stuck closed, you engine isn't getting any air. Have you tried stepping on the gas a little while cranking it? Sometimes that can get it unstuck. It's a 30 dollar part, and easy to install.
starting probs
The IAC valves go bad ALL the time. Mine stuck and made the car idle at like 3000 rpm. Cant hurt to check it but I dont see it being the problem.
Do you guys think its over kill to use a 190 intank pump AND an inline pump as well?
