I have a crazy misfire, please help!!
Old 04-26-2006, 12:37 PM
Prostangmods
Prostangmods's Avatar
Default I have a crazy misfire, please help!!
I have a 2001 with a keene bell making 12psi. Since I installed the kit I have a misfire that you can here at idle but goes away under high load and then comes back at 5000rpm. I have changed plugs, coilpacks, crank sensor, cam sensor, fuel injectors, everything. The car makes 12.8 psi with the 12psi pulley so I don't think its a vacuum leak. Please if anyone has any suggestions help me out. Thanks!!
Prostangmods is offline
Old 04-26-2006, 12:38 PM
Prostangmods
Default RE: I have a crazy misfire, please help!!
I have also had it dyno tuned and the a/f ratio, timing, and fuel pressure are all with in spec. Thanks
Old 04-26-2006, 12:46 PM
hotrodV8
hotrodV8's Avatar
have you done any internal work on the motor
hotrodV8 is offline
Old 04-26-2006, 12:48 PM
Prostangmods
yeah, I did a compression ck everything is fine.........
Old 04-26-2006, 01:00 PM
n/a_threat
n/a_threat's Avatar
Well I was gonna mention to check compression on that cylinder, but you did it already.
Let me offer some other potential reasons for a misfire:
a leaking/damaged intake gasket leaking unmetered air into that chamber
exhaust valve may be hanging open slightly
a slightly recessed/sunken valve for that cylinder
n/a_threat is offline
hotrodV8
hotrodV8's Avatar
ok well i'm gonna kinda give you a list of the stuff that usually comes along with anything over 10 psi, you need a new chip, fuelpump, bigger injectors, mass air flow unit and a new tune, and probably some upper engine work to keep everthing from detonating on you. so not sure what all you have done to it but you cant just slap a supercharger on a car and go.
hotrodV8 is offline
Old 04-26-2006, 01:12 PM
Prostangmods
Here is a list of mods on the car, SCT chip and dyno tune, keene bell boost a pump and in line pump, 42 psi injectors, SCT big air mass meter (tuned to the injectors) 2 step colder plugs from ngk, centerforce clutch and flywheel, mac hig flow hpipe with cats, 373 gears, mac upper and lower control arms, wideband a/f guage, 75 mm throttle body, intercooled keene bell 1.7 ltr kit. I know a great deal about tuning and superchargers so I know you don't just bolt and go. No boost was even closed to applied to the car until it was tuned on a mustang dynometer by guys who tune stangs all day long.
Old 04-26-2006, 02:58 PM
bluepony4.6
bluepony4.6's Avatar
ORIGINAL: n/a_threat
Add to this bad or damaged plugs, plug boots or coils
Antifreeze or water leaked into spark plug hole causing an arc (happened to me).
bluepony4.6 is offline
Old 04-27-2006, 01:39 PM
Prostangmods
Problems fixed, it was a vacuum line to the EGR vacuum control valve. Thanks for all the replys.
Old 04-27-2006, 01:43 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Nice, do you have your factory short block, internals and all?
Dan04COBRA is offline
Quick Reply: I have a crazy misfire, please help!!
