Those of you that have upgraded TB and plenum...
RE: Those of you that have upgraded TB and plenum...
ORIGINAL: 2004blackgt
This is off topic but does the brand matter as for how much increase you get out of it?
click me... click me
Yea i looked at those but i just wanted to know if yall had done any test or anything.
75mm BBK TB and C&L Plenum. No problems.
no problems when i installed my BBK 75MM & C&L plenum , however i installed a diablo program at the same time. if you are going to change these things you will waunt to reprogram or you may have problems(or at least thats what i have read ) you may run to rich or lean or maybe ideling problems.
rw98...
Did you just use the programs on the Diablo tuner, or did you take it to a performance/dyno shop and have them do a custom tune with it?
What programs do you get with the Diablo?
I never said you would have a problem if you didn't change your MAF, I said you would notice much MORE of a difference if it was changed with those other components.
And no not only for FI set-up....A well tuned car is the cheapest HP available.
When I started to put bolt-ons on my 97 4.6L 2v.......I started with:
Ram Air............Custom fabricated costed me about $20
80mm Mass Air.........Bought on Ebay used for $46 (JET)
75mm T/B w/spacer..Bought on Ebay used for $125 Accufab
Upper intake Plenum.Bought on Ebay used for $64 Accufab
24LB injectors...........Bought at a trade show used for $45
Put in 1 step colder plugs.....Dealership $4.29 each
K&N Air filter...Auto Zone for $46.99
Also pulled off the heads and did a 3 Angle Valve Job (used new gaskets cost $46)
All of these cost me less than $425 and added 47HP. My Buddy does dyno work.. We put in on there and it made an extra 47hp
It's great to brag about being on a dyno many times and for FREE non-the-less. Well it cost me a six pack...$7.49 (Heineken)LOL
ORIGINAL: Dragon02GT
+1. I have never heard of anyone having any problems with not changing out their MAF after getting a new TB/plenum combo. I have Accufab 75mm TB and C&L plenum and have never had a problem, expcept for that great increase in throttle response that was cool.
ORIGINAL: rudemood12
whats this about doing the MAF at the same time? isnt that only necessary if moving to an FI setup?
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
