oil help plz!
RE: oil help plz!
10-30 used to standard, just about every vehicle calls for 5-30 now. They call for 5-30 for a reason, the motors are built tighter, and require a lighter weight oil to properly lube them, if you use a heavier weight oil it will not be properly lubed and cause acclerated wear
