short throw
RE: short throw
ORIGINAL: GTboy98
has anybody driven with hurst?
RE: short throw
Listen to vast majority... MGW>all... It has the shortest throws, and spring loaded, plus the 360 degree handle is the best. I don't see any other shifter having the 360* handle that'll help with the position of the shifter in our cars.
RE: short throw
i like my steeda tri-ax... it gives you the satisfaction of controlability... the mgw is incredibly nice with its 360 degree tilt function but in terms of firmness and agility, the tri-ax will not let you down... missing gears is also almost impossible =D i always had problems hitting the 3rd gear with the sotck shifter... now it's like OMFG it slides right in just as if ur pee pee was lubed =D
