whats will i run and how much power
Old 06-08-2006, 06:48 PM
hardtohitme7
hardtohitme7's Avatar
Default whats will i run and how much power
if you guys can let me know what you think i could run it would be a great help
2002 Zinc yellow Mustang GT
Almost 33k miles
stock 3650 5 spd trans w/ pro 5.0 shifter
4.10 gear
31 spline Strange street/strip axles
Aftermarket posi unit
Summit rear end girdle/cover.
Underdrive pullies
SCT custom tune chip... 3 tunes are on the car now.
Hooker Longtube headers
Offroad X pipe
Magnaflow catback.
Accufab intake plenum
75mm Throttlebody
JLT intake tube w/ K&N filter in stock airbox
UPR driveshaft loop
UPR double adj. upper control arms
UPR solid lower control arms
UPR subframe connectors.
No front sway bar
Lakewood 90/10 struts and 50/50 shocks
Tubular K member and stock A arms
Mach1 grill delete
hardtohitme7 is offline
Old 06-08-2006, 06:55 PM
jpmustanggt
jpmustanggt's Avatar
Default RE: whats will i run and how much power
Low 13's and maybe even high 12's
jpmustanggt is offline
Old 06-08-2006, 07:02 PM
code3GT
Mustang Nazi
code3GT's Avatar
The grill delete has been known to cut atleast a tenth off your time.
code3GT is offline
Old 06-08-2006, 07:03 PM
blk40th
blk40th's Avatar
depends on how good of a driver you are. you could hit mid to high 12's
blk40th is offline
ASUSMC
ASUSMC's Avatar
I see the K&N filter and different tube but did you remove the air silencer???? I assume you did but just a question if not all of that air is having a tough time getting to the engine. Cool though good fast car.
ASUSMC is offline
Old 06-08-2006, 07:04 PM
bigedog8
bigedog8's Avatar
who knows what ull run. im guessing 15.5 because of the driver
bigedog8 is offline
Old 06-08-2006, 07:11 PM
97targa
97targa's Avatar
No way you'll run 12's. You'll be lucky to hit low 13's. All that stuff is good, but you have no major engine work.
I have 460hp 496ft/lbs and I'll be lucky to get low 12's street tires. If I run slicks I'll run in the low-mid 11's all day
removing an air silencer or putting in a K&N or a grill delete won't get you a 12sec. car. HP and Tq does.
The longtube headers willhelp your hole shot, but if you have street tires, your just goin to spin.
97targa is offline
Old 06-08-2006, 07:12 PM
amoosenamedhank
amoosenamedhank's Avatar
ORIGINAL: hardtohitme7
Almost 33k miles
4.10 gear
Underdrive pullies
Offroad X pipe
Magnaflow catback.
75mm Throttlebody
UPR driveshaft loop
No front sway bar
Mach1 grill delete
I was told that you couldn't run stock A arms the a tubular k memeber. They say you have to do a front coil over conversion. But people seem to say they do it. So once and for all can you run stock A arms with tubular k memeber or not.
amoosenamedhank is offline
Old 06-08-2006, 07:13 PM
97targa
97targa's Avatar
Ohh sorry forgot to tell you.....I doubt your running 300hp yet
97targa is offline
Old 06-08-2006, 07:18 PM
amoosenamedhank
I have full bolt ons stage 1 cam and I'm only at 286RWHP so I wouldn't see you at more then 250-255.
Quick Reply: whats will i run and how much power
