some questions for u 46er's
ok today a friend just a bought a 97 cobra and wants to mod it to beat me with my 5.0. i am not to familar with 4.6 and thought i would come on here and ask what all he would have to do to it to accomplish his goal. now when i say that i know poeple will say supercharger but i highly doubt that would happen netime in the near future and it will more than likely be a bolt on process.
i do know he already has a strong power plant with the dohc cobra motor. so what would he need to beat me motor for motor.
first of i know gears now my friends step in
2010 Blue Ball Award Recipient
RE: some questions for u 46er's
That depends,, motor for motor.. we' have to know what times you are running with your stroker
I can give you an estimate of what a full bolt on SN-Cobra can run with DR's however
LT's, midpipe, catback, pullies, intake, t/b, plenum, 4.10s-4.30's, nice DR's, and good driver mod could see a 12.8-13.0 I would guess
full bolt on 99-04GT's see anything from a 13.0-13.2.. so his CObra should be good for a bit better than what a GT would run.
anyoen else think this sounds about accurate?
Well I basically just raced your car last night and stayed with it till atleast 80mph. He needs to do pretty much evrything I have (full bolt-on) Start with gears and the aluinum drive shaft. Then go to work on the motor. He probably wont need evrything but the major stuff, udp's, full intake and exhaust and maybe heads?
BBK long tubes Headers
BBK ORHP
BBK Pulleys
BBK 190lph fuel pump
BBK Fuel Pressure regulator
BBK Fuel liquid guage
Ford Racing 9mm wires
super 40 flowmasters
UPR smog pump delete kit
MSD Blaster coil
MSD Cap and rotor
347 stroker fully forged
Balanced rotating assembly
lunati nitrous cam
sct chip tune
zex 125 shot
ford racing lifters
1.6 roller rockers
comp cams hardened pushrods
ac delete
trickflow track heat
3/8 intake spacer
bbk tb 70mm
C&L 76mm kit with MAS
reworked e7's have been ported 3 angle valve job milled 40 185 160 valve's
dual valve springs
double roller timing chain
#30 injectors
msd 6al box
msd rpm selector
msd bronze dizzy gear
zex purge kit
zex rapid fire kit
professional products harmonic balancer
arp head bolts and studs
cap and Rotor
Pro 5.0 short shifter
BBK Adjustable Clutch Quadrant and firewall adjuster
Centerforce Dual Friction clutch
3.73sD&D K-Member new*
D&D Coilovers (150lbs spring rate)new*
D&D tublar a-arms new*
Lakewood traction bars
BBK heavy duty upper control arms
BBK subframe connectors
BBK lowering springs
BBK caster camber plates
solid motor mounts and tranny mount
battery relocated to trunk *new
thats all of my mods but i haven't run it at the track yet and it still needs to get tuned but he is just wanting to beat me like i said i would ask what he needs to beat me.
BBK ORHP
BBK Pulleys
MSD Blaster coil
MSD Cap and rotor
lunati nitrous cam
sct chip tune
zex 125 shot
ford racing lifters
1.6 roller rockers
ac delete
3/8 intake spacer
bbk tb 70mm
dual valve springs
#30 injectors
msd 6al box
msd rpm selector
zex purge kit
zex rapid fire kit
cap and Rotor
its a d&d and its treating me pretty well wasnt that bad to put in and u can tell a weight difference.
so what all would he need to beat as far as bolt ons are concerned and its the dohc 4v yes
