Spark Plugs make me happy!!!
Well i have been having major problems with my track times (9.4 in the 1/8th) and hopefully the new spark plugs will help fix them. I put in the NGK TR55's and am initially extremely happy with the results. Seems my car idles much easier now and engine sounds better overall. Took it on the interstate and feels like a smoother powerband and increased acceleration also. Just hope its not all in my head.
P.S. I bought a can of SEAFOAM but am reluctant to put it in my engine. I want to put it through the vaccum line but am not quite sure which one that is. I would hate to put it in the wrong hose and screw something up so can anybody tell me which vaccum line i should put it in. A Picture would be great if you have one. Thanks.
RE: Spark Plugs make me happy!!!
hear is a helpful video. its old but it works
http://video.google.com/videoplay?do...173&q=sea+foam
just suck some of it up through your pvc valve(tube comes off on the side of your tb) then put it in the gas and oil. peaple say to change the oil after. ive never tried it. my car only has 7k miles on it.
if you look at your plenum straight on, the vaccuum line is the last rubber hose on the right on the side facing you. simply disconnect it from the plastic piece that runs into it, an pour the seafoam directly into it as described in the video.
however, the video mentions to use 1/3 can... id use the whole thing.
ORIGINAL: M1ke
to clean the iac just take off the two bolts and spray some brake cleaner in it
EDIT: That tap with the wrench on Saturday helped a little!! LOL
ShaneB26154
35
03-04-2021 04:05 AM
