Missing 3rd
#21
RE: Missing 3rd
well a few of my friends got the tri-ax also and never had a prob....so mybee a seal in the shifter has failed...but make sure you check your clutch cable(if stock adjust the quadrant) you have to pull up on the clutch pedal all the way the press all the way down..... i had a prob getting into third b4 i changed to tri-ax and it ended up being my cable was strecthed out replaced with steeda adjustable cable, qaudrant and firewall adjuster (mustangtuning.com) has kit for 129.00 i bleave
#23
RE: Missing 3rd
ORIGINAL: Cornbread01
#24
RE: Missing 3rd
ORIGINAL: weasel1088
i actually recently adjusted my clutch like that...i really need to get out and test the shifter fully...cuz now im second guessing weather it still does it after i adjusted it...
#25
RE: Missing 3rd
do you have the stock cable and quadrant... cuz when i adjusted the stock it wasnt as bad but still happened the i replaced with full steeda set up been 9 months no problems one the stock adjuster its plastic so i dont trust it on mine it kept slipping
#26
RE: Missing 3rd
if its plastic two piece quadrant it stock i would deffinitally go with the steeda kit get the adjustable cable, the quadrant and firewall adjuster.... got investment can really control you clutch with it mustangtuning.com is were i got mine for about 129.00
#28
RE: Missing 3rd
thanks for the tip!
