Ratchet Shifter
RE: Ratchet Shifter
http://www.bmracing.com/index.php?id...bcat=1&pid=356
#81001 says for aode 94-00
I think ours are the same as the 2000's.
RE: Ratchet Shifter
Contact your local engineering college and collaborate with them on a solenoid activated system. IE, push a button for park, reverse, neutral, and a couple different drives (cruisin', racin', etc.). Tie it in to the TPS and tach, and you can dial in exactly where you want it to shift, but with a MUCH quicker RT than you could ever hope for.
Might be pricey, but what's a couple hundred between friends....[sm=alcoholic.gif]
junior04
09-28-2015 10:53 AM
