Question!
Old 07-02-2006, 05:53 AM
badboystangGT
badboystangGT's Avatar
Default Question!
when i bought my 98 GT it already had flowmasters umm.. i think an h-pipe not to sure and all cats are removed..my exhaust was cut after the mufflers my tail pipes are still there, there just not welded to the mufflers if i were to weld the mufflers to the tail pipe would the sound change? bad or good? cause right now its really deep and loud
badboystangGT is offline
Old 07-02-2006, 06:21 AM
code3GT
Mustang Nazi
code3GT's Avatar
Default RE: Question!
It will definitely change.
code3GT is offline
Old 07-02-2006, 06:25 AM
SXGT
SXGT's Avatar
get a piece of pipe to aim the few inches of metal after the muffer DOWN. this is called a Dump. it makes the sound reverb off the ground and should magnify the sound you already have. Then just take those tips off and sell them to a v6 er.
SXGT is offline
Old 07-02-2006, 06:26 AM
1BAD3V
1BAD3V's Avatar
So are you saying that there is a gap between the tailpipes and the mufflers? If so, than you are losing alot of power. Go get them things welded back together.
1BAD3V is offline
Old 07-02-2006, 06:28 AM
SXGT
SXGT's Avatar
how do you figure he is losing power?
SXGT is offline
Old 07-02-2006, 06:34 AM
1BAD3V
1BAD3V's Avatar
ORIGINAL: SXGT
If he has a gap between the mufflers and tailpipes, like their not connecting and air is flowing out of them, he is gonna be losing power. Just like when I installed my o/r h-pipe, I only got it have way finished because I needed another tool and the shops were closed, so I drove around with a cap between my h-pipe and catback/tailpipes, whatever you wanna call it, and that car felt so damn sluggish and slow.
1BAD3V is offline
Old 07-02-2006, 06:39 AM
SXGT
SXGT's Avatar
I dont think anything after the mufflers matters thats my personal oppinion. Tips dont create back pressure or reduce any flow that i could imagine. If the cut is before the muffers ok i can see that doing something but not after them.
SXGT is offline
Old 07-02-2006, 06:41 AM
1BAD3V
1BAD3V's Avatar
ORIGINAL: SXGT
I take it that is true. The tailpipes really cant create that much if any back pressure. I was thinking of taking off all my exhaust after the o/r h-pipe, would that reduce power? I know it would be loud.
1BAD3V is offline
Old 07-02-2006, 06:48 AM
SXGT
SXGT's Avatar
I think it would sound like poop without mufflers. you may loose torque from it.
SXGT is offline
Old 07-02-2006, 06:50 AM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: 01SilverGT
ORIGINAL: SXGT
You will probably gain a little power and lose some tq. I dynoed mine with dumps, then put my stock tail pipes back on and dynoed again. I picked up almost 30 ft lbs of tq. Now granted, the tail pipes were stock so with the smaller diameter, some back pressure was created, therefor increasing tq.
code3GT is offline
Quick Reply: Question!
