RUNNING LIKE HELL
Old 07-11-2006, 12:50 AM
99gtstang
99gtstang's Avatar
Default RUNNING LIKE HELL
Ive got a 99 gt few mods, X-pipe, intake and pullies. Lately when i drive in any gear the car jumps almost like it is skipping. Especially while the car is under a load. Such as up a hill or staring in 1st gear. Also I can be driving steady at 75 and it will just jerk once or twice. Drives almost like a bad coil pack. But i am getting no check engine light. Heres the funny part if i throw alot of fuel injector cleaner in it, it will slow down or quit. Ive replaced plugs, springs, and boots. Ive been reading your forums and you guys have got the best anwswers so this is my first post. Thanks
Car has been to a shop and on diagnostics and they say nothing is wrong.
99gtstang is offline
Old 07-11-2006, 12:53 AM
Cornbread01
Cornbread01's Avatar
Default RE: RUNNING LIKE HELL
did you try the fuel filter just a sugestion
or try to reset the computer unplug the battery for 5-10 mins reconect see if its better
Cornbread01 is offline
97 5.0L
97 5.0L's Avatar
probably alot of other people on here know better than me but could it be gears or transmission?
97 5.0L is offline
Old 07-11-2006, 12:59 AM
99gtstang
99gtstang's Avatar
Yea filter new
Old 07-11-2006, 01:00 AM
99gtstang
99gtstang's Avatar
Not sure car does great on that new clutch, no slipping, doesn't feel like rear end for sure in the motor.
Old 07-11-2006, 01:01 AM
99gtstang
99gtstang's Avatar
Will reset everything and see what it does..........
Old 07-11-2006, 02:13 AM
Cornbread01
when i did my filter it ran like crap afterwards cuz i didnt diconect the battery... you have to do so so that the comp can adjust the a/f ratio you probablly getting to much fuel my car did the same thing after reset the comp ran fine hope this helped
Old 07-11-2006, 02:30 AM
mustang_montana
mustang_montana's Avatar
need some more info. first, did it just randomly start doing this, or did it do it after a "mod"? second, describe whats going on, is it bucking while on the throttle or comming off? i really dont quite understand what youre saying, is it bucking under acceleration or part throttle? could be intake related but i really need more info.
mustang_montana is offline
Old 07-11-2006, 09:52 AM
99gtstang
99gtstang's Avatar
its been doing it since i bought it... on and off for a few months. Lately alot more. Only when you give it gas not downshifting or letting off the gas. Does it under light and heavy pressure to the gas pedal. It stutters, drives just like a coil pack went out......hard to describe. Jerks the whole car and taking of in first its struggles almost like its not getting gas. I put a screwdriver to the injectors there all ticking i dont know if that means there working properly. Could it be timing? or could the timing chain be stretched out? maybe the cam caps are loose? Thanks for your replys
Old 07-11-2006, 09:54 AM
99gtstang
99gtstang's Avatar
Yes it did it before and after the mods....
Quick Reply: RUNNING LIKE HELL
