Engine ticking noise *vid*
Click here to watch Engine-Tick--
Had this weird very quiet low pitched tick the year now I've owned the car. It only does it when it's cold and totally goes away when it's warm.
Lately, I've been getting a tick once the car is WARM, opposite of before. It ONLY happens when I'm just BARELY on the gas, and above 2k rpm, like you see in the vid. If I give it anymore gas than JUST a little bit, the noise goes away.
Little background - had the engine out the beginning of May and replaced the rod bearings a piston (new rings and wrist pin on that piston) and replaced all the gaskets. I took the car to Ford a week ago and they say they "think" it "might be" a timing chain tensioner. Idiots.
It sounds a little more serious to me. It's not rod knock because it's not there all the time. Could this be valve train noise? It's just weird that it goes away as soon as I give it any more than a little bit of gas.
RE: Engine ticking noise *vid*
very odd noise, im not quite familiar w/. any shops that know about mod motors around you? i'd ask them. hopefully someone here with more knowledge about out motors can pin-point it, its definitely distinct. sounds like sticking a pen in a fan while its spinning. but a lil quieter.
it didnt seem to increase with rpms, i may be wrong, you would know best. if it does increase w/ rpms , i would definitely say its something in the valvetrain/rotating assembly. if its not, i wouldnt think its your valve train. maybe im wrong, but i hope that helps.
get a mechanics ear and find out exactly where its coming from. is it louder inside than outside? does it happen in gear and out. i know it sucks diagnosing engines, nobody wants to dish out 1-2 grand for repairs.
g/l getting this solved.
yeah it sounds like something from the engine... have you checked the tensioner? when those go bad they make all kinds of noises
and why would they replace only the rings and stuff on that one piston?....... warranty work?
maybe when he had the engine out, and if he did the work himself, he didnt do it quite properly eh? just an opinion. i wouldnt trust my self with a mod motor, unless i did some HEFTY learning.
Yea I did all the work myself but I've rebuilt a few engines and these mod motors are a breeze. The one piston/rings/wrist pin was replaced because it turns out the idiot before me had a s/c on it and destroyed the ring lands. Had to replace that cylinder basically and re-hone that cylinder as well. I doubt the wrist pin went bad in that cylinder since it came from Ford with the new piston.
And actually, the car ran better after I did the rebuild. I went up 5 mpg, and when it was apart, I removed big chunks of DUCT TAPE from the oil pan, and un-clogged the oil pickup tube screen that was half covered in junk including gobs of silicone that the moron had plastered on the engine at all the gasket mating surfaces. I started the engine right up after the rebuild and haven't had to touch it since besides an oil change two days after the rebuild.
