1998gt 4.6 2 v ?'s
1998gt 4.6 2 v ?'s
i want more power from the car...but i dont think the heads on this car are pi heads..can anyone tell me how to check and see if they are ford pi heads and intake...and if they are not can i put better heads stock 4 v or what heads r good to go with and what intake...it has 3.73 gears... cold air kit...9mm plug wires off road xpipe...and delta 40 series flows...power programmer...180 thermo...high volume fuel pump...and a new set of plugs...i ran 13.51 in 1/4 mile with a 113 mph et...someone let me know what heads/intake would be a badd *** combo
RE: 1998gt 4.6 2 v ?'s
the PI swap is pretty common and will raise your compression to a number i forget >_< YOu can get 370cfm heads for $900 thats getting close to as good as 4v
your car is a 98 so it still might qualify for a Intake pi swap from the dealership, the recal was on cars that where so old. I think my 97 wa sone year shy of getting the recal.
Nitrous will be the cheapest mod. That should put you in 12`s in the 1/4 easily if you can drive. To convert to 4v heads, your talking lots of cash. It can be done but it`s not worth the $$$.
You have 3 choices...
1) Take your stock heads to Renegade Racing for the best flowing NPI's available with a SVO/FRPP Intake
2) Get PI heads (99-04) GT heads and intake (can have them ported also)
3) Get SVO/FRPP heads and intake (very expensive but worth the money)
All of these will add a minimum of 50hp to your car.
Cams are also a very big addition. Most will add 30 +rwhp
ORIGINAL: SXGT
