2 quickie questions
2 quickie questions
One:Is there a book out there that perhaps gives the in's and outs of working with our cars (2002 gt), and perhaps some specs and How-to's. I know they make these manuals for older stangs.
Two: What type of gas do you guys fill up with? 87, 89, or 93. I've heard 93 but i heard we can use 89...
What do YOU reccomend?
Thanks !
Thanks !
RE: 2 quickie questions
to answer question number one, i know pep-boys has the haynes manual for the late model stangs... thats the only "book" out there that i know of.
answer to question two, it really doesn't matter until you have modded the hell out of your car and it requires higher octane. like mine, i have higher timming with the tune i have and i can only run 93, no octane higher or lower. stock or near stock stangs can run on all three.
i think they have manuals for are cars already . just do a search on the net u will find something im gonna need one too. and for octane it depends on your mods. if u are stock use what your manual tells u to. i think its 87 or 89. but if u change your timming or get a chip or other modifications might requier a higher grade. so be sure when u do mods to your car u find out wich grade u will need to use.
hey WHT00GT what brand gas do u get i used shell 93 a couple times and i had some hard starts and just didnt seem like it ran that great. C&L told me to run at least 92 cause of the maf. but when i used sunoco it seems like it starts right up and runs a lil better. what u think
ORIGINAL: 04mustang
ok cool let me know i didnt think that there was much diff either but maybe there is. my car just has not had a hard start yet with the sunoco just seems cleaner. maybe some of the other ppl here can test this out to see what brand is the best.
Here are some books I have:
Mustang Performance Handbook - William R. Mathis - This is mainly a 5.0L book
Mustang Performance Engine Tuning - MM&FF - This talks about both 4.6 and 5.0's. This is basically a book with mods from past issues (I guess) as well as some additional information.
How to Build Max-Performance 4.6-Liter Ford Engines - Sean Hyland - This book breaks the car down into about a dozen sections, describes various 2V and 4V components of the system, how sturdy the system is stock, some do's and don'ts, etc. There is a section in the back of the book that contains some build-up packages (not instructions, just package description) There is also a 2001 Cobra build-up description and a spec section.
I would recommend the second two for sure for the late model Mustang.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
