Buying a Cobra
Buying a Cobra
I posted this in the SVT forum but not too many people post in that so I'll post it here too. Im looking to buy a used Cobra preferably a 2001. I was wondering how much do you think I should spend because a lot of the dealerships around here are trying to rip me off, what else is new [:'(] Anyways, any comments are appreciated.
-Mike
-Mike
RE: Buying a Cobra
Go to WWW.Kbb.com or WWW.NADA.COM and look up the retail value off of milage and go from there. I would go with a '03 by the way!
RE: Buying a Cobra
'03 > '01 Cobra. I think there are a lot of similiarities in the engines. Both are DOHC and 32V. I think the '01 has an aluminum block where the '03 has an iron block, of course I'm talking kinda out of my *** on this. I'm sure of the SVT gurus will help you more. '03 has a 6-speed, where the '01 only comes with a 5-speed. '03 is already blown which will make modding it much easier. '03 = 390 underrated hp, '01 = 320hp. Just some numbers and my
RE: Buying a Cobra
wow... 18!!! you better consider insurance also then. I have a '02 GT and on my record is 1 speeding ticket and an at fault accident from three years ago (its coming off next time I renew ) and im 24 and my insurance runs me 280 a month. But I pay it all off for 5 months so I get a small cut off of that. Just look into it if you havent already.
RE: Buying a Cobra
PRICING
Base Retail * $20,280 $35,485
Base Invoice â€* $32,718
New Car Blue Book‡ $35,130
GENERAL INFO
Country of Assembly United States United States
Country of Origin United States United States
EPA Class Subcompact Subcompact
Body Style Coupe Coupe
Doors 2 2
Seating Capacity 4 4
POWERTRAIN
Engine Code / Name 99V 99Y
VIN V Y
Cylinders V8 V8
Displacement 4.6 4.6
Bore x Stroke 3.55 x 3.55 -
Compression Ratio 9.9 8.5
Fuel Type G G
Fuel Induction SFI SFI
Valve Train DOHC DOHC
Valves Per Cylinder 4 2
Total Number Valves 32 16
Horsepower 320 @ 6000 RPM 390 @ 6000 RPM
Torque 317 @ 4750 RPM 390 @ 3500 RPM
Max Eng. Speed 6800 RPM 6500 RPM
Transmission 5 Speed Manual 6 Speed Manual
Drivetrain Rear Wheel Drive Rear Wheel Drive
EPA City - 17 MPG
EPA Hwy - 24 MPG
SAFETY
Airbag Driver
Passenger Driver
Passenger
Child Door Locks Not Available Not Available
Child Seat Anchors Standard Standard
Integrated Child Seat Not Available Not Available
Alarm System Not Available Not Available
Engine Immobilizer Not Available Not Available
CRASH TEST
Driver Front No Data No Data
Passenger Front No Data No Data
Front Side No Data No Data
Rear Side No Data No Data
Rollover Rating No Data No Data
DIMENSIONS
Head Room: Front 38.1 inches 38.1 inches
Head Room: Rear 35.5 inches 35.5 inches
Leg Room: Front 41.8 inches 42.6 inches
Leg Room: Rear 29.9 inches 29.9 inches
Shoulder Rm: Front 53.6 inches 53.6 inches
Shoulder Rm: Rear 52.1 inches 52.1 inches
EPA Passenger 83.0 cu.ft. 83.0 cu.ft.
EPA Trunk or Cargo 10.9 cu.ft. 10.9 cu.ft.
EPA Total Interior - 93.9 inches
WARRANTY
Basic 3 years or
36000 miles 3 years or
36000 miles
Powertrain 3 years or
36000 miles
Corrosion/Rust Thru 5 years or
Unlimited miles 5 years or
Unlimited miles
FEATURES
2W Anti-Lock Brakes Not Available Not Available
4W Anti-Lock Brakes Standard Standard
Front Air Conditioning Standard Standard
Front & Rear Air Conditioning Not Available Not Available
Cruise Control Standard
AM/FM Radio Standard Standard
Cassette Not Available Not Available
Compact Disc Standard Not Available
CD Changer Standard Standard
Premium Radio Standard Standard
DVD Entertainment System Not Available Not Available
Cup Holder Standard Standard
Leather Optional Standard
Navigation System Not Available Not Available
Privacy Glass Not Available Not Available
Hands Free Phone Not Available Not Available
Power Locks Standard Standard
Power Outlets Standard Standard
Power Mirrors Standard Standard
Remote Mirrors Not Available Not Available
Power Seat Standard
Dual Power Seats Not Available Not Available
Folding Rear Seat Standard Standard
Moon Roof Not Available Not Available
Sun Roof Not Available Not Available
Remote Keyless Entry Standard Standard
Luggage Rack Not Available Not Available
Rear Window Defroster Standard Standard
Tilt Wheel Standard Standard
Tachometer Standard Standard
Traction Control Standard Standard
Power Windows Standard Standard
Upgraded Wheels Optional Optional
Power Steering Standard Standard
SPECIFICATIONS
Wheel Base 101.3 inches 101.3 inches
Overall Length 183.5 inches 183.5 inches
Width 73.1 inches 73.1 inches
Height 53.2 inches 52.5 inches
Curb Weight 3430 lbs. 3665 lbs.
Tires / Wheel Size P245/45ZR17 P275/40ZR17
Rear Tires / Wheel Size - -
Spare Tire Compact Compact
Wheel Type Aluminum Cast Aluminum
Turning Radius 37.9 38.1
Brakes: Front ABS
Disc ABS
Disc
Brakes: Rear ABS
Disc ABS
Disc
Fuel Capacity 15.7 15.7
Axle Ratio 3.27 3.55
Ground Clearance - -
GVWR - -
Maximum Towing 1000 NR
Transfer Case - -
Payload Base Capacity - -
Truck Bed Volume - -
GENERAL INFO
Doors 2 2
POWERTRAIN
VIN V Y
Cylinders V8 V8
Fuel Type G G
EPA City - 17 MPG
EPA Hwy - 24 MPG
SAFETY
Airbag Driver
Passenger Driver
Passenger
CRASH TEST
DIMENSIONS
WARRANTY
Basic 3 years or
36000 miles
36000 miles
Unlimited miles
FEATURES
Power Seat Standard
SPECIFICATIONS
Brakes: Front ABS
Disc ABS
Disc
Brakes: Rear ABS
Disc ABS
Disc
GVWR - -
Transfer Case - -
RE: Buying a Cobra
ORIGINAL: AhhCobras
I would also go with an 03' but I'm only 18 and can only afford so much
JDaniel....dude, you're getting ripped a new one. It was $3900 a year for me to have a C5 Vette....I have 6 points on my insurance. I advise looking elsewhere.
