4.6 v8 hesistation
Old 06-08-2004, 12:45 AM
E.smith
E.smith's Avatar
Default 4.6 v8 hesistation
i recently bought a 2000 gt mustang. in the first day of owning it i've had a hesitation problem. i have changed fuel filter, spark plugs, and the boots that go around the bottom of the coil packs.i've had the codes read twice and neither time has a code come up! my brother tested the coil packs and they were all close to the same voltage. the problem seems to be intermittent in that it goes from somewhat of a problem to a major problem in a matter of hours of driving. any help would be greatly appreciated, i can't seem to find a fix or a suggestion on the forum[:@]
E.smith is offline
Old 06-08-2004, 01:12 AM
jdaniel
I ♥ Acer
jdaniel's Avatar
Default RE: 4.6 v8 hesistation
No offense but I drove a 2000 vert and I think its just that year. The power difference was unreal. Dont know why. My car didnt have the mods then it does now, but it still seemed so slow!
jdaniel is offline
Old 06-08-2004, 10:29 AM
WHT00GT
WHT00GT's Avatar
ORIGINAL: jdaniel
???????????????????????? my car ran fine stock. maybe that vert was screwed up or something.
E.smith:
what plugs are you running? it almost sounds like a misfire. you might want to try some fuel system cleaner as well...
WHT00GT is offline
Old 06-08-2004, 04:20 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
Where is the hesitation? Is it off idle or high in the RPM band, or anywhere in the RPM band?
Dan04COBRA is offline
Old 06-08-2004, 04:41 PM
94mustang2003
94mustang2003's Avatar
like if u hit on the gass ull go and when u let off it will like jolt a little it really pisses em off even when i got trac control off
94mustang2003 is offline
Old 06-08-2004, 04:52 PM
WHT00GT
WHT00GT's Avatar
so it only happens when you get off of the gas?
WHT00GT is offline
Old 06-08-2004, 04:56 PM
Dan04COBRA
Super Moderator
Dan04COBRA's Avatar
I don't think you can call that hesitation when you let off the gas and it 'jolts' forward. That would be a product of fords loose drivetrain.
Old 06-08-2004, 04:59 PM
WHT00GT
WHT00GT's Avatar
ORIGINAL: Dan02GT
i was just getting ready to say the same thing..... it definitly gets annoying, but you get use to it.
WHT00GT is offline
Old 06-09-2004, 05:09 PM
94mustang2003
yup damnit it is so annoying can i get it fixed
