Heads and Cams, Please help!!!!!!!!
Old 08-15-2006, 12:20 AM
TeflonDon
TeflonDon's Avatar
Default Heads and Cams, Please help!!!!!!!!
I've been going back and forth trying to get some answers about my next project before i waste my money. I'm in the process of buying new heads and cams and posibly a new intake if i have to. hotrod on here told me, that there is a posibility of porting the stock heads that i have now, to have the same flow as new PI aftermarket heads with a .600 lift. He was also saying that there might be a posibility of getting some cobra heads, but he wasn't sure if they would fit.
I'd really like to know all the info i could before i go out and blow $3000 on stuff that i really don't need, or stuff that just wouldn't work for my setup. I know what a lot of you guys are going to say $3000? why not S/C for a few more bucks, well i'm not trying to go that way, i want a N/A sports monster!!! These are my mods to my car so far:
BBK Shorty Headers, SLP X-Pipe, SLP Loudmouth CB, BBK CAI, Diablo Tuner. She's an automatic as well. there are the parts i planned on going with so far: Please take your time and click on the links and let me know if that's going to work?
Heads:
http://www.mustangtuning.com/patriot...104-romeo.html
Cams: the stage II on that page
https://www.rpmoutlet.com/musv8cam.htm
Injectors:
http://www.mustangtuning.com/stfuin.html
Intake:
https://www.rpmoutlet.com/musv8dynotune.htm
Throttle Body: The BBK combo with 75mm
https://www.rpmoutlet.com/newv8cm.htm
MAF: 80mm?
https://www.rpmoutlet.com/musv8mmmff.htm
Please reply back, and give me all the advice you can. As you can see that's a lot of money just to through away and order the wrong stuff, so if you know a better combo, or where i can get that stuff cheaper please help!!!!
TeflonDon is offline
Old 08-15-2006, 12:25 AM
TeflonDon
TeflonDon's Avatar
Default RE: Heads and Cams, Please help!!!!!!!!
also, just curious. If I did want to S/C would i still have to do the heads and cams, or can i S/C with stock cams and heads and intake
Old 08-15-2006, 12:33 AM
droptoppony
droptoppony's Avatar
ORIGINAL: TeflonDon
Heads:
Injectors:
Intake:
MAF: 80mm?
I wouldn't buy half the stuff on that list...Patriot = JUNK!!!!!
PP Intake = JUNK
that MAF= JUNK
and you will most likely not need injectors until you are over 330rwhp or so...
ok for heads and cams go here.. www.vtengines.com
your stock intake is fine same with stock maf and injectors.
Put the money into your automatic tranny...like a torqe converter and valve body.. go here http://www.bc-automotive.com/
droptoppony is offline
Old 08-15-2006, 12:40 AM
TeflonDon
TeflonDon's Avatar
What should i get first? or just get it all at ones? what does patriot = junk?
Old 08-15-2006, 12:44 AM
droptoppony
patriot sucks just take my word for it and forget about them i don't feel like digging up all the bad stories about their bad quality.
Well obviously you should do the heads/cams first with the plenum/tb...then get a good dyno tune. Add to that the built auto tranny and your car will feel like a new monster.
TeflonDon
TeflonDon's Avatar
wtf is a valve body for, and what is it?
Old 08-15-2006, 12:46 AM
droptoppony
ORIGINAL: TeflonDon
here some reading for you...just about everything you will need to know about your auto tranny
http://tccoa.com/articles/tranny/tra...on/index.shtml
Old 08-15-2006, 12:56 AM
TeflonDon
TeflonDon's Avatar
dude, thanks for those webpages. i really really really appretiate it. damn, no spell check hope i spelled that right [8D]
Old 08-15-2006, 12:59 AM
droptoppony
ORIGINAL: TeflonDon
no problem...the mid 90's cougars/Tbirds had the 4.6 engine and auto tranny like us and they all had the auto so those guys know what to do...
Old 08-15-2006, 01:08 AM
TeflonDon
TeflonDon's Avatar
with my setup that i have right now, and i get a 2800 stall converter. fromt he vt webpage, what heads and cams would you get if you could? also, what does this mean
Stage 1 CNC ported Romeo core heads. Flow 200/180 cfm. Come completely assembled with Ferrea stainless valves and Comp valve springs. Minus rockers and lifters. Outright priced - no core required.
Quick Reply: Heads and Cams, Please help!!!!!!!!
