4.10 and 0-60
RE: 4.10 and 0-60
04- Im not one for going to the track but as far as having some fun, smoking
the tires, is the 4.10 the way to go or do you think it is better to start doing other
mods such as exhaust, intake etc etc to make it faster?
RE: 4.10 and 0-60
the most bang for your buck mod is gears. if you wanna roast them till the cows come home than get gears. but traction on the stang is a bitch and if you get gears it wil be real hard to hook up. gears arent a bad mod but you are not going to get ther full benefit unless you get some drag radials and suspension mods. its really up to you what you want first but you wont feal much from just a intake or just a catback. you need the hole shubang to really feal the power. i went with exhasut and intake first since they both work together to make power and you need one to make the other work better. but gears are the best bang for your buck its up to you.
RE: 4.10 and 0-60
im 4.2 seconds with car below 3.73s....got to have some wrinke walls if you want to hook and that time was easin out the hole so it wouldnt spin,,,only hooks at the track in hot rubber 1.55 60fts,,at track
junior04
09-28-2015 10:53 AM
Figure8allday
08-22-2015 11:11 AM
