shift kit any good?
shift kit any good?
got a 02 stang gt, auto...slp 330hp performance pac(long tubes, hi flow cat, cat back exhaust,pullys,180stat,tuner with custom tune from slp) also have cold air intake with larger tb and manifold, and 410 gears ... would a shift kit do anyhting for me or is it just a waste of money? on mydiablo sport predator tuner there is a category on there that lets me adjust my shift firmnss, so i just turn it up sum with the tuner or get the shift kit? or both? thanks in advance!
RE: shift kit any good?
Start by moving the shift firmness all the way up and feel it... then imagine that shift except stronger with a shift kit. If the tuner's firmness adjustment is enough for you then you won't need the shift kit BUT if you do get the shift kit, return the firmness on the tuner back to normal.
I had XC2 before shift kit & I definitely noticed a difference . I have "transgo" shift kit . here's the link .
http://www.transgoperformance.com/
oh ok, and what exactly are the advantages of a shift kit, besides firmer shifts, would good will that do? how much more wear or damage do you tihnk it'll do to the tranny? how hard are they to install?
ORIGINAL: 88TurboFord
it will improve durability & longevity . I would also highly recommend a trans cooler . I have a B&M super cooler , but any will do .
ORIGINAL: SVTBill
hey how much was that slp pro pkg? does it really give you 330 like it says? dyno proven. also, i may be about to get an auto GT tomorrow so info on the shift kits will be great
