stock exhaust removal
Most likely ordering magnapacks in the next few days...Anyways I just wanted to make sure I knew what I am about to get myself into when I install it.
For removing the stock exhaust do I just saw the stock catback off where it meets the rear axel (before the muffler i assume?) and unbolt it from the hpipe. Is that basically all there is to it?
Thanks for help
Thanks for help
RE: stock exhaust removal
Yes, that is what you do. you can cut the exhaust wherever it comes off easiest for you. You also have to unbolt your exhaust hangers from the car (at least with my SLP catback) and replace them with the new hangers. Make sure you put the hangers on the exhaust BEFORE you bolt them to the car. It makes it much easier.
ORIGINAL: eventer289
how to you drop the axle, just remove the shocks?
could anyone with magnapacks confirm if they needed to unbolt the hangers?
Its simple. You just unbolt two 10mm or so bolts on each one. Even if you dont have to put new one's on removing the stock hangers and putting them on your new system will make installation a lot easier.
