Traction?
Traction?
I searched and only thing i really seen was Control arms.....
Can i just replace the lower control arm?
Any suggestions for keeping tires on ground. Other then tires...........
Everything is factory except the Springs. i just replaced My back sits about .5-1 inch higher which is causing them to spin in 1st and 2nd.
Advise from someone who knows
THANKS
THANKS
RE: Traction?
ORIGINAL: Mark99GT
Not sure what you're asking. You just installed springs and the rear end of the car is sitting 1/2 to 1 inch higher? <THEN THE FRONT>
Yes The whole reason i lowered my car was the front sat higher now i see why to keep all the weight on the back tires. Well I used a 1.12 front and .75 out back and now the front sits lower so no weight is really transferred when full throttle in 1st. and 2nd.
RE: Traction?
ORIGINAL: 99gtstang
ORIGINAL: Mark99GT
RE: Traction?
ORIGINAL: thornton02GT
weight will still get transfered because your engine lifts at wot....
ORIGINAL: 99gtstang
ORIGINAL: Mark99GT
The main reason is becuase on my way to work saturday i took a turn and the tires broke loose and i went into the ditch... nothing bad just broke the bead on my tire making small air leak but i got it fixed
RE: Traction?
ORIGINAL: lizzyfan
[sm=wtf.gif]
[sm=wtf.gif]
I know i have had several threads about my problem i seem to be the only one that has had this problem...
Ok if i get sub frams any brand? or do they all do the same thing?
lower rear CA recommendations? adjustables?
