Anyone using the gas strut hood lifts
Old 11-26-2006, 02:36 AM
code3GT
Mustang Nazi
code3GT's Avatar
Default Anyone using the gas strut hood lifts
Just as the title says. I want a set for the bucket and want to get a set for the Mrs for Christmas. These are the ones I am looking at.
http://cgi.ebay.com/ebaymotors/2005-...QQcmdZViewItem
code3GT is offline
Old 11-26-2006, 02:39 AM
99gtstang
99gtstang's Avatar
Default RE: Anyone using the gas strut hood lifts
nice, much easier to work with no bar in your way all i have is half beating struts on the trunk
99gtstang is offline
Old 11-26-2006, 02:46 AM
99gtstang
99gtstang's Avatar
120 for 99-04 GT thats high
Old 11-26-2006, 02:48 AM
BleedinBlue
BleedinBlue's Avatar
So far I've only seen one Mustang with these...they worked great and are original. I might throw a set on my car eventually, after I make her a little less slow.
BleedinBlue is offline
Old 11-26-2006, 03:35 AM
doughboy4.6
doughboy4.6's Avatar
I have them they are nice
doughboy4.6 is offline
Old 11-26-2006, 03:36 AM
code3GT
Mustang Nazi
code3GT's Avatar
ORIGINAL: doughboy4.6
Easy and clean install???
code3GT is offline
Old 11-26-2006, 07:39 AM
olesch
olesch's Avatar
I recently buyed struts for my hood, but I buyed the ones from MRT. No drilling required.
I am a little sceptic into drilling the hood and then fasten the brackets with rivets, since the hood is not metal the rivets might upon time tear up the drilled hole.
The MRT ones just bolt on into the original bolts which holds the hood.
Just my 2 cents =)
olesch is offline
Old 11-26-2006, 08:08 PM
doughboy4.6
yes drill 8 holes in total and put rivets in all
Old 11-26-2006, 08:21 PM
stang2000
stang2000's Avatar
I have some as well. If you do it right, you'll never have any problems. I've had mine on for 2 years now and never have had any problems. Simple install. I am not sure how they'll work with an aftermarket hood though. You might check the area where the hood mounting brackets go, to make sure you have the same clearance and or space to mount.
Mine are redline tuning also, which I bought off ebay. Also you'll have different bracket mounts for different years. so get your model year only. Also remember to double check the mounting area since you have an aftermarket hood. Unless they're not going on your silver car.
stang2000 is offline
Old 11-26-2006, 08:24 PM
stang2000
stang2000's Avatar
Here is a picture of mine. I can go take closer pics if you wish. Let me know.
[IMG]local://upfiles/5875/C0396F5997874B7B8FCCB38FAA548994.jpg[/IMG]
Quick Reply: Anyone using the gas strut hood lifts
