gears
gears
i just bought a '01 gt and i know the car had some mods on it but were taken off but i think it may have gears. i read that most places put a plate with the gear numbers on it on the rear end. i have a plate and here are the numbers.......5229h and 1127881h22. has anybody seen these numbers on a stock gt or know if these are a part number to aftermarket gears?? thanks......
RE: gears
Nobody puts a new tag on the rear for a gearswap - the tag will only tell you what came factory and yours came with 3.27's. Aside from removing the gears to count the teeth, you can jack your car up and look rotate the tires and compare that with the rotation of the driveshaft, or you can go out on the interstate in 5th gear and track your mph vs rpm's and let us know what they read and we'll let you know what ratio is in there.
RE: gears
i actually switch into 5th after i cross the line, im at redline in fourth when i crossed the line.
by jacking the car up and rotating the wheel, how do i tell a difference between gears?
ill drive with my gps tomorrow and see what rpm's im pulling at 70 mph, would that help?
i didnt want to do it today bc it just rained and i washed and waxed my car.
RE: gears
ORIGINAL: neogenic83
i have 3.73's and i run 2300 at 70 souns like 4.10's or mabe even high
Do you have an auto because everyone here I have talked to says that they run about 2300 to 2400 in fifth with 4.10's.
