is this asking too much?
Old 01-23-2007, 10:05 PM
Fuel
Fuel's Avatar
Default is this asking too much?
i have a 96 gt and i was wondering if i could yeild somewhere near 375-400rwhp with my wishlist
pi or stage 1 blower cams
FRPP supercharger @ about 10psi
boost cooler injection system
i need to do something with my engine as it is at 198k miles, but i really don't have a lot of money so i was wanting to just rering it for about $450 and add the supercharger
or does anyone know how would this work if i did the head swap and ran high compression and lower boost, my horsepower goal is under 450hp so i really don't want to send a lot of money on an extensive rebuild and not have anything left for a blower
thanks i am done rambling now[sm=icon_blah.gif]
Fuel is offline
Old 01-23-2007, 10:08 PM
bransdaman78
I ♥ Acer
bransdaman78's Avatar
Default RE: is this asking too much?
you should make that power EASILY... give or take some boost
bransdaman78 is offline
Old 01-23-2007, 10:09 PM
ZW99GT
ZW99GT's Avatar
PI heads and intake? Not 400
ZW99GT is offline
Old 01-23-2007, 10:12 PM
Fuel
Fuel's Avatar
the FRPP supercharger is an eaton unit so i wouldn't need any intake, it has its own
Fuel is offline
Old 01-23-2007, 10:14 PM
SVTBill
SVTBill's Avatar
donno if this is true or not but ive heard that you can "warp" not really warp your cylinders but if you put so many miles on the engine that your cylinders wont be perfectly true anymore...so...if thats the case your rings would have "warped" with the cylinders too...so (if this is true) getting it reringed would actually make it burn (more) oil (if its not already)...so that could actually be a bad idea...if what im saying is true thennnn you need to bore it out...in which case...if i had to bore it...id try to make the power n/a since its already bored...maybe some nitrous too...is it PI already? (someone help me out on this logic plz)
SVTBill is offline
Old 01-23-2007, 10:20 PM
Fuel
Fuel's Avatar
it doesn't use hardly any oil at all so i think that the rering would do everything that it needs to
the real question here is wether or not i can make the power i want without having to do the pi swap, or if i did the pi swap wether or not i would have to change pistons
Fuel is offline
Old 01-23-2007, 10:21 PM
Fuel
Fuel's Avatar
help me out here droptoppony[sm=feedback.gif]
Fuel is offline
Old 01-23-2007, 11:12 PM
Fuel
Fuel's Avatar
somebody?
Fuel is offline
Old 01-23-2007, 11:16 PM
GAYstang
GAYstang's Avatar
i got the solution, pull the engine and hen throw in a ls1
GAYstang is offline
Old 01-23-2007, 11:22 PM
Fuel
Fuel's Avatar
i would rather cut off both my hands than put an ls1 in my mustang[sm=boosign.gif][sm=forgetit.gif][sm=lame.gif]
Fuel is offline
