Check Engine Light
Old 01-30-2007, 06:38 PM
02GTman
02GTman's Avatar
Default Check Engine Light
I was on my way home today and my check engine light came on, I stopped by AutoZone and had them read the code it was P0125-Closed loop fuel Control---Insufficient coolant temp. I called my buddy at the Ford dealer and he said the codes that they give you at AutoZone are not the same used by the dealer. He said it may be the T-Stat. What do you guys think. Thanks,
02GTman is offline
Old 01-30-2007, 07:08 PM
99GTvert
is my username.
99GTvert's Avatar
Default RE: Check Engine Light
ORIGINAL: 02GTman
hm....anyone else find this to be a little fishy?[&:]
99GTvert is offline
Old 03-06-2008, 05:24 AM
mrlzbones
mrlzbones's Avatar
I am getting the same po125 trouble code. Did you ever get a bottom line answer for this?
mrlzbones is offline
Old 03-06-2008, 12:33 PM
GolfmanSpeck
GolfmanSpeck's Avatar
In the "How To" section you can find the Trouble codes. This is what it list for that one:
"P0125 Insufficient Coolant Temperature to enter Closed Loop."
I would replace your coolant temp sensor (about $20), and see if that clears it up.
GolfmanSpeck is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
Quick Reply: Check Engine Light
