Clutch Sugestion
Clutch Sugestion
Well guys this Spec Stage 1 clutch is a real PITA its been in my car for over 2000 miles and still is chattering and making my car less enjoyable it also got very stiff and i have a feeling its about to crap out on me. Its gotta come out...I need a suggestion because I really enjoy stock engagements that dont chatter and so forth. Should I got stock GT clutch or should I upgrade to the terminator clutch. I know the pedal on those things are pretty stiff but anything is better than this POS I have now
RE: Clutch Sugestion
you cant go with a clutch off of a term. the trans in the terms are t56 6 speed trans. they have different ammount of splines. i know the t-45 and the trem 3650 have different spines so i would think the t56 and trem 3650 would
if hes got the 3650 they dont make a king cobra for it. did you install it yourself? it shouldnt chatter after 2k miles, try going back to the shop where you got it installed and complain..... or buy a duralast clutch from autozone, they replace it if it ever wears out... i found this hard to believe but a buddy of mine has been doing it with cluches and brakepads for a while haha
ORIGINAL: nanaki
operator error. i have like maybe 800 miles on my spec 3 and the chatter is gone. get a king cobra. i hear they're good.
ORIGINAL: 5speedstang
the person you know that says a king cobra lasts an oil change is obviously rediculous, i had a king cobra for over a year with no problems and i sold the car..... he obviously cannot drive. i would do a spec 2 or a centerforce if i were room, just more power room over the stock clutch
ORIGINAL: djb1187
well i have the spec clutch for a 01.5+-04 since my car is a late 01 but i had a t45 for some reason. would that cause all my problems?
yes! Thats your problem right there.. you have the wrong setup... how did they even get htat to work? did the replace the flywheel, etc? thats.. very odd..
I have a spec stage 3 and I really never had any chatter.. just a tiny bit when taking off before I got used to the slip point.... spec's are usually really good about not chattering.
