4.10s
Old 03-22-2007, 02:49 PM
99 GT vert
99 GT vert's Avatar
Default 4.10s
i am looking to get some 4.10s what all will i need before i have them installed
thanks
99 GT vert is offline
Old 03-22-2007, 02:54 PM
2002GTAUTOVERT
2002GTAUTOVERT's Avatar
Default RE: 4.10s
Patience and a tuner to compensate the speedo for the new gears.. while ur down there put in a tranny cooler if you have an auto
2002GTAUTOVERT is offline
Old 03-22-2007, 03:00 PM
99 GT vert
99 GT vert's Avatar
Default RE: 4.10s
how much will a tranny cooler run
and i go camping near brenspeed and i will probly have them install the gears
Old 03-22-2007, 03:15 PM
BraMas
BraMas's Avatar
Default RE: 4.10s
I would get a bearing kit. I always suggest replacing the wheel bearings if your not sure when the last time they where done.
BraMas is offline
Old 03-22-2007, 03:17 PM
99 GT vert
99 GT vert's Avatar
Default RE: 4.10s
how much would a wheel bearing kit cost
Old 03-22-2007, 03:18 PM
97targa
97targa's Avatar
Default RE: 4.10s
ORIGINAL: 99 GT vert
They sell everything needed for that install, so just get it from them. I think they carry all motive gears which are pretty descent. You'll need a master assembly kit with bearings! The pinoin bearing gets trashed if you try to pull it off the old one as do the seals! Make sure you tell them NOT to use the cork gasket for the housing cover. It will dry up and crack and leak. Tell them to just use RTV sealant as they prob. will anyhow. Your looking at I think they get $180 for 4:10's and $80 for the master install kit! Plus maybe $350-$450 for install
97targa is offline
Old 03-22-2007, 03:21 PM
99 GT vert
99 GT vert's Avatar
Default RE: 4.10s
i would get all the stuff from them but i can get the motive 4.10s for 120 should i still buy those instead of getting them from brenspeed
Old 03-22-2007, 06:00 PM
99 GT vert
99 GT vert's Avatar
Default RE: 4.10s
when installed should i have then do anything else to make sure it is done right or will it be alright
mtgldr
02-03-2024 09:00 PM
junior04
09-28-2015 10:53 AM
stealth_GT
The Racers Bench
09-22-2015 02:19 PM
Figure8allday
08-22-2015 11:11 AM
Darrens07GT
08-10-2015 03:59 PM
Quick Reply: 4.10s
