Did you lower with only springs?
RE: Did you lower with only springs?
Depends on how much you drop it... Most people say you can drop it up to 2" and be perfectly fine.
I did the eibach pro kit (1.5" drop) and couldnt be happier and had no problems.
i did. had 1.5" springs installed and it still sits like a 4x4. i was told if i replace the struts it will drop on down but i don't know if this is true. i hope it'll work.
[/align]
unless you plan on doing more than 1.5" (like 2-3") you're fine. Beyond 1.5" youmay need a bump-steer kit, camber/caster plates, and probably new ball joints that offset the control arms so they are back in geometrysquared with the rest of the suspension. Shorter sway bar links is a must too for 2" or greater and new shocks/struts for the 2" or morein travel you just lost.
And before anyone says anything. There is a right way and a wrong way to lower a car. Drop a stang 2" or more you will have suspension that is out of geometry and will adversly affect handling and wear on your suspension.
1.5" is the easiest and cheapest.
ORIGINAL: trublu02
[/align]
[/align]
Now if you go with Coil overs (strut and spring on one frame) those are adjustable.
Ya just got 1.5".... You will be paying an easy $500+ just to get that extra half inch or so... And if you still think you sit like a truck after getting the pro kit you should probably just get a honda and slam it so that when you bottom out and your car dies noone will care
If you are only dropping it 1.5" you should be fine without caster/camber plates and the bumpsteer kit. I would recommend replacing the shocks and struts, since lowering springs are stiffer than stock you need a shock that can handle the increased demands.
