2003 Cobra help
2003 Cobra help
I just got a 03 Cobra this weekend and the ABS light is on. The guy I got it from said that when he changed the rotors the ABS started acting up so he had to pull the fuse on it. The light is still on though. Does any one know why this would have happened? Why the ABS would act up after changing the rotors.
RE: 2003 Cobra help
Sometimes when people change brakes stuff will fall and get in between the abs sensor and the little wheel they need to sense. Go to each wheel with some brake cleaner look for the the little round thing that has teeth on it and the sensor will be right there also just clean up the area. Maybe even blast the area with some air. Disconnect the negative side of the battery while you do it to give ECM a chance to reset when your done.
11-10-2015 11:39 AM
junior04
09-28-2015 10:53 AM
