Are adjustable cam gears worth it?
Old 04-23-2007, 02:38 PM
JimboGT01
JimboGT01's Avatar
Default Are adjustable cam gears worth it?
Specifically these....
http://www.jegs.com/webapp/wcs/store...2331_-1_108215
JimboGT01 is offline
Old 04-23-2007, 04:19 PM
oxfordgt
oxfordgt's Avatar
Default RE: Are adjustable cam gears worth it?
I have heard of those shattering and destroyiing engines. Go with comp ones if you need them. What cams are you putting in? VT you shouldnt need them but comp you will.
oxfordgt is offline
Old 04-23-2007, 04:21 PM
ben790450
I ♥ Acer
ben790450's Avatar
IMO its not worth it. Ripping apart the timing cover and valve covers just to adjust your timing. Forget it!
ben790450 is offline
Old 04-23-2007, 04:32 PM
Mark99GT
Mark99GT's Avatar
Im pretty sure Findaza makes the gears for Comp. Some people's have slipped and/or broken, resulting engine damage. You can grind the keyway on the stock gears if you're degreeing cams.Adjustables are not a necessity.
Mark99GT is offline
Old 04-23-2007, 06:09 PM
yoteehunter
yoteehunter's Avatar
They are worth it if you degree your cams. It makes the job 10XXXX easyer and less work.
yoteehunter is offline
Old 04-23-2007, 06:32 PM
Dsmfighter
Dsmfighter's Avatar
DON'T WASTE YOUR MONEY!!!! I've heard of alot of these failing..
[align=left] [/align]
Dsmfighter is offline
Old 04-24-2007, 02:31 AM
BuzzCut
BuzzCut's Avatar
Grind the keyways on the stock gears. The adjustables are junk and will ruin your motor sooner or later.
BuzzCut is offline
Old 04-24-2007, 03:55 AM
crawlingGt
crawlingGt's Avatar
they are not worth the money at all im am trying to sell my for 150 still brand new in box. the stock ones are the way to go the adjustable ones will come lose and mess everything up. the shop by my house in plainfeild are using stock ones on there 05 mustang and it runs 8.50's
crawlingGt is offline
Daddys Girls GTs
09-14-2015 08:46 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Pyrate Dave
09-10-2015 07:30 PM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Are adjustable cam gears worth it?
