Trying to fix the P1443 Code, I have done a few of the basics
So I bought this car from the dealer a week ago. After two days of owning it the CEL came on. Had it checked at Autozone and of course it was the
P1443 code. I looked at the service stuff that the dealer had done, oil, tranny fluid,... vapor system error.. so it says they bought the canister purge vavle (for $105, lol). I checked under the hood and the valve looks new, so I will assume they actually did change it. So I filled her up with gas and tightened down the gas cap(3 clicks). I disconnected the battery last night and guess what... check engine light came back on after warm-up. I didnt have the code read yet, but I am going to assume it is the P1443 agian. So what do you guys think I should do/check next? Replace the canister purge sensor? Gas cap?
-Update: I had the code read again last night and I got two codes, both P1443.
I also purchased another gas cap and disconnected the battery... and the CEL came on again today.
I talked to the dealer today and they said that the mechanic did change either the purge valve and/or purge sensor, changed the Idle Air Control, and they also did a smoke test (I guess to check for vac leaks between the purge valve and the intake).
Any ideas on what to do/check next?
The dealer told me to bring it back and they would take care of it. The only thing is the dealer is over an hour away, and they are the ones who couldnt fix it in the first place.
What do you guys suggest?
Thanks
Thanks
RE: Trying to fix the P1443 Code, I have done a few of the basics
https://mustangforums.com/m_3144914/...tm.htm#3146481
Already explained it to you... That is the only piece that you need, called a canister purge valve... I bought mine from www.rockauto.com and it's only $17....
Are you postive they changed that one.. or could they have changed this one...
because I know when I went into the parts store they had both under the same name...
But I went through your trouble... I changed the carbon canister/and this piece above, and still had the light on... Then went with the other one and that fixed my problem..
I work for a dealership and if I sold a car that had a check engine light that came on shortly after I sold it, I would have it fixed. If they are a Ford delaer they have an obligation to you as a consumer to fix it.
ORIGINAL: gt96stang
ORIGINAL: Rebornmust_owner
ORIGINAL: gt96stang
ORIGINAL: uofipilot
Where is the canister purge valve on the 97 (mine's a cobra but i'm assuming its in the same place as the GT)? I got the CEL with this code one the drive home from buying it from a private seller. I wanted to drive all the way back and smack him in the mouth. I've been putting it off till the emissions notice comes, and it came. Dam. I already replace the PCV valve on the drivers side valve cove, but that didnt do it. Anyway, thanks.
ORIGINAL: gt96stang
