any one with longtube header experience
Old 05-02-2007, 03:07 PM
yellowgtstang18
yellowgtstang18's Avatar
Default any one with longtube header experience
Im goign to have my headers put in next week, Mac ceramic longtubes.. Do i need front o2 extensions. I have heard yes and no. Websites show the o2 extensions a must for 04 gts but says nothing about 99-03. And also do i need to buyt new gaskets...?????
yellowgtstang18 is offline
Old 05-02-2007, 03:11 PM
Ryan86272
Ryan86272's Avatar
Default RE: any one with longtube header experience
I didnt buy any Extensions but i Extended them Myself.....(just cut, use Bconnector, and Heat Shrink) I added the Wire needed. I cant remember about the Gasket to tell u the Truth. I know i didnt buy a New one, maybee one came in the Box with the BBK Headers. But yeah Good Luck its a Fun Job
Ryan86272 is offline
Old 05-02-2007, 04:00 PM
JT76
Moderator
JT76's Avatar
ORIGINAL: yellowgtstang18
Mac didnt give me new gaskets, i went and bought fel-pros from autozone which work great, they say use the stock gaskets, but just go and buy new ones for insurence, they are dirt cheap. Yes you need front O2 extensions.
JT76 is offline
Old 05-02-2007, 04:06 PM
bigd65
bigd65's Avatar
Yes you need O2 extensions. but i used my stock gaskets works fine and no leaks.
bigd65 is offline
Old 05-02-2007, 04:10 PM
yellowgtstang18
wheres the cheapest place to get front o2 extensions
Old 05-02-2007, 04:37 PM
Js04sILVerBullet
Js04sILVerBullet's Avatar
Isthis y some headerbrands only list 99-03 and not 04 cuz of the 02 sensoror is there another reason cuz i am lookin at some headers but they say 99-03 even tho 99-04 is the same body style?
Js04sILVerBullet is offline
Old 05-02-2007, 04:56 PM
bullitt#1600
bullitt#1600's Avatar
i have an 01 and i installed slp long tubes. they came with new gaskets. u can buy then any where. ford,autozone,checkers
bullitt#1600 is offline
Old 05-02-2007, 06:04 PM
yellowgtstang18
will bbk o2 extensions work with mac longtubes http://www.americanmuscle.com/bbk-o2...harnesses.html
Old 05-02-2007, 06:30 PM
yellowgtstang18
any one i need to order these soon if bbk front o2 extensions fit mac longtubes
Old 05-02-2007, 07:08 PM
PSR
PSR's Avatar
just buy the extensions I can tell you from a tuners point of view that if you use but connectors and extend them your self you are bound to have tuning problems. RPM out let has them all the time and they are cheap. the gasket on the passenger side should be replaced sometimes them stay together but hey it is better to be prepared then not to be. If you don't want to use the extender you can replace the 02s with 24" units they fit fine just for doing that same application. when you use a B connector you are changing the resistant value of the wire due to the added crimp adjuster. Not wise. as for the block gaskets I would use your stock ones but then again I would have some factory replacements just incase laying there. you can buy longer 02 sensors from Auto zone , checker , Napa if you are looking for just the extensions RPMoutlet , PSR , and many others carry such a thing. but for the record I would just buy the longer 02 sensors and be done with it,,[/align][/align][/align][/align][/align]Good luck [/align]Dan[/align]
PSR is offline
GimpyHSHS
19
12-19-2023 01:12 PM
Roxon68
03-17-2016 08:13 PM
junior04
09-28-2015 10:53 AM
trashxtrash
09-20-2015 10:49 PM
BrantleyS550
09-14-2015 04:18 PM
Quick Reply: any one with longtube header experience
