Gas Pedal and IAC Mods....
i just did them both, and wow. it makes a huge difference. both took me about 10minutes each, and it makes a hell of a difference.
if anyone has any questions or concerns about these two mods, just ask me. im sure i can help.
RE: Gas Pedal and IAC Mods....
IAC mod:
https://mustangforums.com/m_2625353/tm.htm
gas pedal:
https://mustangforums.com/m_1297650/tm.htm
gas pedal:
ORIGINAL: 00TropicGreenStang
I think the gas pedal mod ****ed up my TPS. A Ford tech who is around my age (20) who also owns a Mustang advised against it.
ORIGINAL: yourmom6990
hmmm. how do u think it messed it up??
Well from what the mechanic told me the computer relearns it's idle by what the sensors send it. The mechanic said the mod might have took too much slack out and made the TPS read wrong. So basically the computer thinks the throttle is open farther then it is and makes my idle hang. It may not have messed it up but he was just suggesting it to me. I took the mod off my car and took the battery cable off to reset my comp so I will see what comes out of that.
ORIGINAL: Triisomy21
How long did you make your "spacer?" It seems I only have about 3/4" of slack after I raise the gas pedal.
What a crappy place to have to squeeze yourself into huh?!
