How hard was it? Don't they just slip in over the existing gauges or somthing?
i did wash the tires, its just that i drove it into that garage type thing and they got all dirty
the gauges were not hard at all, its very easy, all you do is just remove the screws around the black bezel frame, then remove the screws holding the gauge cluster in, remove the 2 plugs in the back, take some more screws out to get the clear shield off, slide the new gauges over the old ones, make sure everything is fit and the needles can move, then put everything backtogether, then tap into a 12v positive, and ground the other wire (i hooked mine up to my night lights), and your good to go, very easy install
